CEN Racing This forum is to discuss all CEN Racing products.
Clutch Bell
Old 05-29-2006 | 06:41 PM
JonnyLightening's Avatar
My Feedback: (8)
Default Clutch Bell
I wanted to know if you get ball bearings with the 16 tooth clutch bell. I had a hard time getting my stock clutch bell off and broke the bearing and $10 for a bearing seems pretty steep. By the way I thought that the clutch bells were easy to come off I tried taking it off when I first got it and it didn't budge. anyhow thanks for your help.
Old 05-29-2006 | 07:03 PM
Default RE: Clutch Bell
You are talking about a funfactor?
THe clutch bell should come pff pretty easily once you remove the end screw. I guess if your bearing was whooped, it would make it a bit stiffer.
None of the clutch bells that I've ordered came with bearings. I dont know where you saw the bearing for 10$...
I am assuming that you are talking about the 2 5x8x2.5 bearings that sit right in the clutch bell.
They are $4.99 for 16 at www.customrccars.com
http://www.customrccars.com/product_...at=22&custom=0
hope that helps
Old 05-29-2006 | 07:18 PM
craigb's Avatar
ORIGINAL: dustin7837
DOH!! ordered parts from them the other week... wish i knew they had them bearings because i need a load and the model shop is a ripoff!
