CEN Magnum NX
CEN Magnum NX
Just wondering how everyone's Magnum has held up to bashing? Mine should arrive this week. Can anyone tell me of any problem areas that should be attended to prior to beating this truck regularly? What are this truck's weak points? Can anybody pull wheelies with their Magnum? Couldn't pass this truck up for the money. I'll be running with a Savage X and a Tower Teror. Think it'll keep up? Thanks. [8D]
RE: CEN Magnum NX
[link=http://youtube.com/watch?v=_MInspsAzV8]my video[/link]
here is a video of the truck being bashed the real bashing is toward the end of the video
NC
RE: CEN Magnum NX
The key problem with this truck is continusly stripping spur gears.Trust me,you will see what I mean in a short period of time.They do offer steel spurs but they will chew the aluminium pinions.They do offer a steelgeared clutchbell,but the crimp is so terrible that its also a waste of money.Me and a couple others have complained and cen could fix the problem by offering threaded steel pinions(same as stock,but steel)but no luck so far.Some may beg to differ,but trust me,you will see exactly what I mean.
RE: CEN Magnum NX
Thanks for the info and video guys. I'll keep the spur gear issue in mind. Is this truck going to be able to keep up with the Terror and Savage X? I realize there is a bit of a scale difference, but the Magnum's lighter weight should erase some of that difference right?
RE: CEN Magnum NX
this is a direct fit with no mods needed, I have it and it gives a Savage a run for its money[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP7&P=ML]O.S. 18CV-RX w/11J Rotary Carb[/link]
NC
RE: CEN Magnum NX
I have an o.s. engine on mine.I also run 15/18 pinions.The stock motor didnt do well with that gear ratio,so before you go changing gear ratios,make sure you have enough motor to push it.Go to www.neweramodels.com and you will find every mod possible for a magnum.The big block kit,wheely bars and every aluminium part available for the magnum.The truck they have pictured is a MT2 orMT SPEC3.0 but dont worry because the only difference between it and the magnum is the body.I do like the red and yellow truck body better than the blue magnum body.Good luck and I hope this info is helpful.
RE: CEN Magnum NX
Thanks for all the info everyone. I have 6 tanks through it and it seems pretty good so far, no signs of stripped gears just yet. I haven't really run it that hard though. Engine fires up easily and seems like a willing candidate for the job.
RE: CEN Magnum NX
NC
RE: CEN Magnum NX
Half to 3/4 of a gallon.Will probably last longer if you dont jump.Grass is a issue but mostly because of ground clearance.It would do fine on a golf corse but doesnt have enough ground clearance for tall grass.
RE: CEN Magnum NX
NC
RE: CEN Magnum NX
Not looking for anyother trucks.Would be nice to run the one I already paid for.This is not a compairson of vehicles,its about correcting an issue that should have never been an issue.So what are you saying?If youre saying that I should accept this just because it cost $300.00,you got it wrong,and the answer is yes.The MG16 is only$200.00 and has a slipper clutch so it wont even go through gears like this.And what do you mean by OUCH?Dont make this into something that its not.OUCH,if the truth hurts enough for you to say ouch,its not my fault.You know as well as I do that Im not the only one with this complaint.So theres your answer cen123.Any more questions?[:-]
NC
RE: CEN Magnum NX
Dont know about the redcat,never owned one.Probably cant beat the magnum now that cen has an upgraded clutchbell.Redcat is a knock-off in my book.Thats just MY opinion,redcat may be a winner for you,but Im not going to be bothered with it.
RE: CEN Magnum NX
Will from what I've found out about redcat they are pretty decent. the main things I'd have to worry about is where to get parts. I've also read the radio system's horrible. I have a dealer to get parts and I have a separate radio system.
CA
RE: CEN Magnum NX
Hey check out my premier 4 im selling only for 220 and my funfactor rally wrx. http://www.jerrygo.com
Jump on this deal while you can.
RE: CEN Magnum NX
Hey Lightwieght... Don't know if you remember me but we have chatted in the mini section..
Anyway what do you think of the truck as of now? Were do you guys get parts? Were do you get the updated gears? Thanks for any help or other info.
CA
RE: CEN Magnum NX
You can get them directly from us for your convinience:
www.cenracingdirect.com - order today!
