CEN Racing This forum is to discuss all CEN Racing products.
ADVICE NEEDED PLEASE
Old 10-24-2007 | 03:01 PM
Default ADVICE NEEDED PLEASE
HI,Ive just bought a genesis truck from ebay for my son,I know nothing about them but obviously am willing to learn as Is me that is going to have to show him how to look after it(hes 9!).Right,I went and got some after run oil as Ive read you need to use it.I took the car to the field to run the last out of the tank(because the guy hadnt)So i could put some of this oill in.I got it started ok,ran it gently round for a bit,then Im not sure what happened but it cut out.All batteries were fully charged,there was still fuel in the tank.I started it going again but it sounded like it was really over revvin??When i gave it a squeeze the wheels didnt move.It still carried on with the noise,bit smokey too.Im not on here to be chastized for not knowing because eveyone needs to learn.Id really like any help if anyone has time to give me any advice??Pleeease!!:-)Its a genesis 46 7.7 ??
Old 10-24-2007 | 03:45 PM
Default RE: ADVICE NEEDED PLEASE
hi billie, have you properly broken your engine? also, you say its over reving without the wheels moving, lift the truck and see if the propeler shafts are rotating, if props rotating but the wheels arent, check that linkage there, there might be loose screws.
Old 10-24-2007 | 04:03 PM
Hiya,I bought it for 200 quid off a guy on ebay,it looks like new.He said hes used it 4/5 times and had got through 1/2 a big tub of fuel.I didnt rag it about,just took it steady as i was just after a quick go with it before putting the after run fuel in and storing it away for his xmas present!!It did sound an awful lot noisier like engine was really revving but there was no input from anyone on the transmitter trigger
Old 10-24-2007 | 05:48 PM
This is your car http://www.cenracing.com/cars/gst/gst.html
Old 10-24-2007 | 05:52 PM
Since you are getting it for your 9 year old son set the EPA throttle adjustment down to like 50% to start off with. EPA means end point adjustment. Go through the menu and you'll find it.
Old 10-24-2007 | 05:55 PM
I forgot to tell you. The 7.7 means that the engine is a 7.7 CC engine. The 46 means it's a .46 cubic inch engine.
Old 10-25-2007 | 04:12 AM
Hiya again,thanks for that :-) Im learning...slowly with help from people like yourself who has time for beginners and not just the experianced!!The one i have isnt like the one on the link you put.Its like this one http://www.raidentech.com/cenewge46nig.html sorry for confusing you!!
Old 10-25-2007 | 12:10 PM
CEN Racing's Avatar
if all the drive parts seem tight move properly the next place i would look is in your tranny you might have stripped gear or something it might have accidently gone into reverse while moving and coudl have chunked the tranny gears. also if the motor seems like it is revving up while just sitting and not moving anywhere the idle is most likely set way to high you need to turn the idle down its the screw that is on the front of the carb towards the base its a black screw head. to turn the idle down you will back the screw out counterclockwise turning.
Old 10-25-2007 | 06:18 PM
That is pretty much the same car. The GST is the next generation of the Genissis.
Old 10-26-2007 | 02:30 PM
Hi,Ive had it in to a shop today,charged me 20 quid labour to fix it,which i didnt mind as I dont yet know what to do!!Seems to be ok now!!Thanks ever so much for all your advice :-) Seems you were right,the cogs werent meeting and there was a pin sticking out that shouldnt have been???Anyway,fingers crossed it'll be a lesson learned,let my son know what the switch is for!!I hadnt realised and he musnt of realised he'd done it either,but seemingly thats was the most likely cause!!!Thanks again
Billie[sm=red_smile.gif]
Old 10-26-2007 | 02:32 PM
Oh and i did get a 'why on earth you get this for your first car!!'
All got to learn some how,n to be honest,would pay not much less for a smaller one than what i paid for this !!
Besides,If need advice and want to learn,this looks like a great place!!!:-)
