CEN Racing This forum is to discuss all CEN Racing products.
GST 7.7
Old 05-01-2008, 11:47 AM
  #126
The Real Dogman's Avatar
Default RE: GST 7.7 NOT MADE TO RUN, BUT NICE TO LOOK AT!!!
Reiko, Thats why I firmly believe everyone has a good side to them, sometimes you just havta break threw the crust to get to it. And some people are a bit harder to crack the shell, kinda like pistachio nut!![)]
ORIGINAL: Reiko
I can't believe this thread recovered from that carnage. The first several pages have been edited and hopefully everyone can stay on track here. The topic has wavered a bit which is not too bad, but what will not be tolerated at all is attacking other members, flaming, and taunting. There is useful information here, so please do not let the arguing lead to a lock.
Now, the topic may continue [sm=thumbs_up.gif]
Old 05-01-2008, 11:55 AM
  #127
nomobux's Avatar
ORIGINAL: The Real Dogman
ORIGINAL: Reiko
pistachio nut ?? <<<<< they gotts those in Tooocsan ??
Old 05-01-2008, 12:18 PM
  #128
Yep Groves and Groves of them, you see the groves lined up along I-10 for miles
Old 05-01-2008, 08:14 PM
  #129
nomobux's Avatar
Well !!!! I'll be DogDamned !!
Old 05-01-2008, 09:06 PM
  #130
Yeah,, you will!!!
Old 05-03-2008, 08:09 AM
  #131
hey guys sorry about the no pics yet working on that issue now... we installed the new clucth bell and started running it yesterday.. we were treaking on second gear.. but all we could do is either have it lock in first or lock in second.. now we were making headway when the new i said new clutch bell broke the center out again... does anyone know what is causeing this... and do you think cen will send me anthor for free... this clutch bell had less than a tank of fuel ran threw it... it acted like it wont to shift a couple times but still no shift... the clutch bell really has me fired up... so what do you thank dogman....
Old 05-03-2008, 08:14 AM
  #132
Im having a problem changing gears period I bought my genesis from a guy anmd i want to know what I should try first .Im stuck in first gear wont shift winds thru 1 gear well but no shifting
Old 05-03-2008, 08:18 AM
  #133
well i dont know i can either lock mine in first or its stock in second... r u haveing any clutchbell issue's ?????????????????????????
Old 05-03-2008, 08:25 AM
  #134
well i dont think so its a brand new clutch bell
Old 05-03-2008, 08:27 AM
  #135
also whast a good drop in motor for genesis i wanna upgrade after all this talk i ve heard that the 5hp is a myth and only getting 1.8 or something like that
Old 05-03-2008, 09:12 AM
  #136
nomobux's Avatar
ORIGINAL: mrpricelessp
I'm quite sure that after you dial the truck and motor in, you will find the power more than sufficient for your needs.
Old 05-03-2008, 10:08 AM
  #137
where's the dog man i broke anthor clutch bell
Old 05-03-2008, 10:25 AM
  #138
Hey Jamie, We really need to see some high resolution pics of the broken bell and shoes as I stated in the other thread you started. I would have to really think about what could be causing this one, but I'm sure its simple really. Get those pics and we can go from there.
And yes, the power numbers of the NX 7.7 is very hard to believe, but remember those numbers are subjective. All manufactureres are going to want you believe they have the most power, but as NOMOBUX said, once you have the motor tune in right you find plenty of power for any need you might find. In fact, these motors do enough power to destroy some very strong parts in the drive train of ANY RC truck.
Old 05-03-2008, 10:35 AM
  #139
burningpoo's Avatar
I'm thinking maybe something is hanging up and causing heat or even stoping the bell dead in it's tracks. Is there anything exposed past the edge of the shoes? How's the mesh, is it binding up?
About the 5hp, every test I've seen they did it wrong or didn't show info on how the test was done. My truck has a big pair, felt like every tank brings my truck to life more.
Old 05-03-2008, 03:35 PM
  #140
This propably happened.....
http://www.rcuniverse.com/forum/m_7305904/tm.htm
The set screw bushing backed out of the clutchshoe.....ruined the bell..got a ******* explanation from Cen as to why it had happened.
I think it is a design error, maybe when the clutchshoe gets hot, the bushing detaches from the plastic and backs out.
Oh yeah, the debris destroyed the gear case + diff case also [:@]
Old 05-05-2008, 10:05 AM
  #141
no mine broke the center out of two of them
Old 05-05-2008, 10:13 AM
  #142
nomobux's Avatar
ORIGINAL: jamie
Are you setting up an extremely tight pinion setting or something, is it straight and not cocked creating alot of pressure. .. we need some pics
Old 05-05-2008, 02:46 PM
  #143
here they are r post more
ID:	943514   Click image for larger version
ID:	943515   Click image for larger version
ID:	943516   Click image for larger version
Old 05-05-2008, 02:48 PM
  #144
ok the one set of pics is the first clutch.. we tried to fix it yesterday the new one is still on truck
ID:	943518   Click image for larger version
ID:	943519   Click image for larger version
ID:	943520   Click image for larger version
Old 05-05-2008, 02:51 PM
  #145
i think AS YOU CAN SEE i know the pics arent very good .. but the center just broke out and the clutch bell is blue from heat... i just got off the phone with cen they said this was normal.. for it to get hot.. but it wasnt normal for the center to break out
Old 05-05-2008, 04:17 PM
  #146
burningpoo's Avatar
How many tanks have you ran through the one on the truck now?
Old 05-05-2008, 04:26 PM
  #147
burningpoo's Avatar
To tell you the truth, I think your binding up somewhere. What do you use to set your mesh? Unless something in the tranny is getting stuck, I think it's hanging up and making the shoes slip like I've never seen before. I'm almost at a gallon and a half and my bell isn't scorched like yours is, just getting a tan/brown color on mine.
Old 05-05-2008, 04:52 PM
  #148
nomobux's Avatar
That puppy got WAY HOT !!
Old 05-05-2008, 07:24 PM
  #149
Jamie!!! Poo is on to something!!! You have a major problem there bud!! Sure the CB will get hot, but not that hot!! what is happening is your CB is getting VERY hot on the outter clutch surface and not so much in the center. The CB's are hardened steel so when they are exposed to that kind of heat then cooled down they can and will get brittle/crack at the thermal zone(Where the hot meets the cool), creating a weak spot. You need to find out why you are cooking the Clutch before you change another CB. I would check all everything on your drivetrain. In fact when your truck is up off the wheels try to rotate the wheels and see how easy it is turn. Everything should spin freely!!
By any chance are you driving this truck in tall weeds or grass??
Old 05-05-2008, 08:00 PM
  #150
burningpoo's Avatar
jamie, do you run with your fuel line on the head like that?
Can you get a better picture of the gear teeth? I can't tell if it's the light or if your teeth are starting to eat the outer edge.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
