Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
Reload this Page >
when do you change the ballbearing?
CEN Racing This forum is to discuss all CEN Racing products.
Old 10-20-2008, 04:11 PM
lambo77
Default when do you change the ballbearing?
when do you change the ballbearing of the GST's engine?
how many litres or gallons do you do before changing the ballbearing?
Old 10-21-2008, 07:37 AM
derrick05
Default RE: when do you change the ballbearing?
My front started leaking in the 12th gallon.Although it didnt affect the tune,I could tell because all of a sudden my after-run oil started leaking out,and the way I maintain my truck,I knew it was a problem.The rear bearing was in good shape and the front looked good,however after I changed both bearings on a complete rubuild my after-run oil doesnt leak out of the front bearing anymore
Old 10-21-2008, 11:32 AM
lambo77
ohh...after 12 gallons! i'am thinking to change the ballbearing after 6 gallons!! Am i a stupid?
Is there anybody else that can advice to me?
thanks
Old 10-21-2008, 11:38 AM
burningpoo
burningpoo's Avatar
If your seeing anything leaking or you feel extra slop when checking the bearings you should change them. If you run on sand alot then you might need to, that stuff is killer on parts. Do you race? If so you should change ur bearings often because you never know when .1 of a second will help. But as long as everything is working fine just clean/oil them and have fun. hope this helps
Old 10-22-2008, 07:12 AM
derrick05
ORIGINAL: lambo77
thanks
Why would you be stupid?[:@]
Old 10-22-2008, 01:02 PM
lambo77
'cause i believed to change the ballbearings too much soon.
