RCU Forums
-   CEN Racing (https://www.rcuniverse.com/forum/cen-racing-310/)
-   -   Question regarding the remote control (https://www.rcuniverse.com/forum/cen-racing-310/10063726-question-regarding-remote-control.html)
hijack564 10-12-2010 08:37 AM
Hello everybody,</p><p style="text-align: center"><span style="font-size: larger">
im new to this game and i have couple of questions.</span></p>
1- while im playing the car and it went beyond ofthe possiblerange ,which is very short by the way, i relaized that the car kept going and i couldnt control it anymore. This cause alot of damages. My question is this thing normal or might be there some possible ways to force the car to stop when it goes beyond the acceptable rang ?
<u>2-</u> what is " high end needle" and what does it do ?
thank u and i hope no grammer mistakes this time http://www.rcuniverse.com/forum/js/f...wink_smile.gif
</p>
dustin7837 10-12-2010 05:26 PM
RE: Question regarding the remote control
1. Get a fail safe! http://www.venom-group.com/itemdesc.asp?ic=0620 (or similar)
This way, when you run out of range you can have the failsafe adjusted to apply the brakes and center the steering.
2.
http://www.youtube.com/watch?v=9e0ka...eature=related
http://www.cenracing.com/downloads/E...Doc%20NX76.doc
Another useful page for the genesis (non engine related) is this 2nd and 3rd gear guide. http://www.cenracing.com/downloads/23speed.doc
Brett185 10-12-2010 11:23 PM
If Ok, rule #1...Never ever run a nitro car without a failsafe! EVER! This is one of the most basic rules u need to know. Now, when it comes to the needles, the high needle is used for tuning the top end of ur engine, ( half throttle to full throttle), this needs to be tuned first, ( in most cases, especially stock engines ) u want to lean it out till u hear the engine running strong, but still with a little smoke when running at full throttle, I prefer to lean mine out till it's at max power and sounds really good, then back it off a hair to leave it a little rich to lengthen engine life. Remember, the leaner u run it, the higher the temps, and the shorter ur engine life. Also, only turn the needle about an 1/8 turn at a time. Now, as far as the LOW NEEDLE is concerned, it the most tempermental of the two, it will control from take off to half throttle. U may notice some lag in the take off of ur car when the low needle is rich, u want to lean it out with very very small increments, like a 1/32 at a time or even less, lean it out till u have a good strong and smooth take off and smooth transition to full throttle. A good way to test the low needle is to pinch off the fuel line about a 1/2 inch from where it runs into the carb body. If it revs up for a second then shuts off, ur good. If it revs up and continues to rev, ur still rich, if it shuts right off, ur lean. If u still need help, just let us know, that's what we're here for.
hijack564 10-13-2010 10:38 AM
thank you alot , still one thing. SHOULD i buy the same one in the picture or <u>any type</u> will do for my cen genesus.
Brett185 10-13-2010 08:28 PM
Any one will do, just make sure it's a name brand one.
hijack564 10-13-2010 09:28 PM
thank you but would you please recommend one specific type which fits my CEN GENESUS. By the way, i have this one is it good although it seems doesnt respond or maybe i didnt know how to fix it.
would u plz explain where to connect it and how to adjust it to brake.
thank you all for your cooperation</p>
hijack564 10-13-2010 09:30 PM
<span style="color: #ff6600">thank you but would you please recommend one specific type which fits my CEN GENESUS. By the way, i have this one</span>
http://www.mypicx.com/10132010/failsafe_of_cen/
Brett185 10-27-2010 11:33 PM
Well I use an OFNA brand one, all you do is connect it between your throttle servo and your reciever. Plug your throttle servo into the failsafe, and plug your failsafe into the reciever. Now, turn on your transmitter then turn on your car. Next, hold the program button on the failsafe until it starts to blink, while holding the button, apply full brake, tthe failsafe will start to blink after about 5 to 10 sec. then release the brake. It should be programmed. Just follow the instructions that comes with the failsafe. To test it, turn on both your transmitter and you car, then turn off you transmitter, your throttle servo should go to full brake, if not, check your programming instructions and reprogram.
dirtdemon6 10-28-2010 01:28 PM
I had some serious signal problems with the new 2.4 GHz Genesis radio/reciever.  Sent it to CEN for inspection.  Using and FM system for the time being.  <div>
</div><div>Though it sounds like you have the FM system, any one else have problems with the 2.4 GHz?</div>
