lean idle
my engine when it idles it has a lean idle and revs up and down then wants to stall i cheacked around the head and backplate were the pullstart connects the crank and it doesnt leak
RE: lean idle
bmxdirtrider88
First off... what vehicle do you have? So that we can better help you. CEN RACING |
RE: lean idle
its a yokomo rx .18 engine in a stadium truck and i think its because the front crank bearing leaks air, some people say its suppose to be sealed so no air can leak and some say its suppose to leak air. i blow on the fuel line with my finger over the carb and air come out easily and i sprayed water on the bearing when it was idleing and it sucked it in and stalled the engine. my engine doesnt have a low speed needle and the only way it will run without stalling from lack of fuel is around 4 to 5 turns out on the high speed needle and it runs like crap and sizzles water drops right off the head instantly after about quarter tank, the bearing only has a metal dust cover not a rubber seal so the cause of it too hot and lean sholdnt be an air leak in the bearing because the factory would have put a rubber sealed bearing if its a problem. i have sealed all the possible air leak areas and nothing worked, the engine has about half gallon through it and the piston and sleeve is worn because of the overheating problem im having, it ran ok for about a week and then i started having problems
RE: lean idle
i found the problem when i had the whole engine apart it was a crack right under the motor mount i found it on the inside and its cracked all the way through
RE: lean idle
Hmmm....
Perhaps you should contact Yokomo to see about the warranty regarding that particular engine. We recommend our NX 3.0 engine .18. Part # (G70356) It will fit into your stadium truck perfectly and it is extremely easy to tune. It has a top end, bottom end and idle screw adjustments. Regards, CEN RACING |
| All times are GMT -8. The time now is 07:50 PM. |
