RCU Forums
-   CEN Racing (https://www.rcuniverse.com/forum/cen-racing-310/)
-   -   Fail Safe (https://www.rcuniverse.com/forum/cen-racing-310/3238981-fail-safe.html)
mulletman 08-07-2005 09:02 AM
Fail Safe
will any fail safe just plug into my mt2? or do only some?
poor judgement 08-07-2005 09:03 AM
RE: Fail Safe
should be ok with pretty much any as far as i am aware. i have the gws fs-1 in mine and it fits fine, works well too.
mulletman 08-07-2005 09:04 AM
RE: Fail Safe
ok do you have a site i could go to and look at it or do you have all the specs?
poor judgement 08-07-2005 09:07 AM
RE: Fail Safe
google is good...
mulletman 08-07-2005 03:49 PM
RE: Fail Safe
ok thanks
cenracer1 08-07-2005 09:02 PM
RE: Fail Safe
I'm not familiar with a gws failsafe but I use the venom one... I only use them in all my nitro trucks and they have saved me many times... I'm not sure what specs you are looking for... Yes its small and comes in a beautiful green color... As far as I know, they all will fit into the cen/Airtronics receivers....
mulletman 08-08-2005 08:12 AM
RE: Fail Safe
ok thanks ill check that out
mulletman 12-27-2005 10:51 PM
RE: Fail Safe
does any one here have a venom temp fail safe?
what is the best place to mount it?(ya, i still havent got my truck together but I've been busy over christmas)
TRAXXAS829 12-27-2005 11:27 PM
RE: Fail Safe
My MT2 has been running away lately, and I think I'm gonna get a xtm failsafe.
alvinl 12-28-2005 10:30 AM
RE: Fail Safe
I have 2 of the Venom temp failsafes and switched back to the standard ofna and duratrax failsafes. I had a problem with the wire that runs around the cooling head wearing through and shorting out. All kinds of freaky things happen then. You can buy replacement cables and Venom even sent me one for free. They are a good company and I really like their temp failsafes, but I could not keep the temp sensor wire intact. You might have better luck than I did. I had mine mounted on top of the receiver box.
poor judgement 12-28-2005 11:37 AM
RE: Fail Safe
can u slide a bit of fuel hose over the cable to stop it chafing thru?
cenracer1 12-28-2005 02:52 PM
RE: Fail Safe
1 Attachment(s)
here is an older pic of my mt2 with the original engine... The venom failsafe mounted on the servo is 2 years old and still has the original wire probe.. The location and the fuel tubing really help
poor judgement 12-28-2005 07:14 PM
RE: Fail Safe
how neat and tidy is that? man, thats more colour coded than an essex boys 1988 ford escort rs turbo. and thats sayin something. how do u do it?
more to the point - whats with that strange T junction in ur fuel line to the carb? :)
alvinl 12-28-2005 07:57 PM
RE: Fail Safe
Hmmm. Never really thought about putting the wires through fuel tubing, I must admit that is a good idea. The part of the line I had a problem wearing out was the part of the cable at the very center where it goes around the cooling head. It is thicker than the rest of the cable and it would get spots where the metal cable would come through then it would ground on the motor. Maybe I didn't keep it tight enough around the head, not sure.
mulletman 12-29-2005 10:43 AM
RE: Fail Safe
well i dont have any fuel tubing but, mounting it on the servo looks like a good idea(how did you stick it to the servo)
alvinl 12-29-2005 07:09 PM
RE: Fail Safe
A strip of velcro should work to hold it in place. You could also use a good double sided tape, maybe like the tape you can buy at the hobby shop to hold the receiver in place. It's thicker than normal tape, very sticky and provides a bit of cushion.
cenracer1 12-29-2005 07:40 PM
RE: Fail Safe
ok.. here's the deal... its not a t-fitting just the way the picture was taken.. standard routing of the fuel lines except an extra fuel filter.. I run clear tubing after the filter to see when the fuel reaches the carb when priming..
I run the temp probe loop just under the cooling head at the point where the head and the block meet.. this way the wire works well and doesn't get too banged up....
I use super duty velcro not the standard type and I used shoo goo to fix to the servo... I remove the venom unit alot and I still have the original velcro.. works very well.. I also used it to mount the venom failsafe to the front of the radio box with great results... I tried double sided tape but it falls off when it gets wet.....
poor judgement 12-29-2005 07:44 PM
RE: Fail Safe
mulletman 12-29-2005 11:27 PM
RE: Fail Safe
man im slow!!!!!!!!!!!!! i was planing to finish up my truck today(fail safe, fuel filter etc.) but we had "family Christmas" im so mad[:@]
Tune71 12-30-2005 06:55 AM
RE: Fail Safe
I tried the modelengines failsafe in mine and it disagreed with the throttle servo so went to a venom and its fine
mulletman 01-19-2006 06:25 PM
RE: Fail Safe
- 20C , cold, no real hurry to get my truck to together. Where do i mount the temp sensor on the motor for the venom temp fail safe?
