steering servo issues
The other day I cracked the steering arm that connects to the servo horn. I think it's part g73910 but anyway, I glued it back together and it was steering beautifully. Until that is a gear in the stock steering servo cracked. I went out and bought a hitec high tourque servo to replace it which also worked great for about 3 tanks until the gears in it stripped. Just looking for some advice here on anything I could check that might be cause the gears to strip. I was thinking perhaps there is too much travel and the wheels were sort of locking in place but I'm still not sure. Any input would be appreciated.
Thanks, Frosty |
RE: steering servo issues
Sounds like your servo saver is stuck and not working..
Ya, you gotta watch that setting on the servo saver. I killed the stock servo, and a JR 188oz metal gear servo in the same week. Actually in two runs... LOL. Since then i have backed it wond a bit, and havent had any problems with the Hitec 645 servo.
| All times are GMT -8. The time now is 03:47 AM. |
