CEN MT2 Pull-start question
MT2 seems to offer the best value on the market. I am very interested getting one
but have some questions regarding the pull-start. 1) How hard is it to pull start the engine? Within 5 pulls? 2) Will the pull start break easily? 3) Can you use a electric starter instead? Thanks all (still try to decide between MT2 and TNX ...) |
RE: CEN MT2 Pull-start question
1) Hard to answer... if the engine is in good tune, no air leaks, primed correctly, not overheating etc etc... then its just the same as pretty much any other engine - sometimes just one pull, sometimes half a dozen or so, but its not really an issue so long as the tune, temp etc is ok. My OS engine starts and holds a tune a little better than the Cen motor - if thats any help, but theres not a lot of difference other than power tbh.
2) Only if u pull it out too far - a flick of the wrist is all it needs. 3) I believe u can, I think its the Tiger Drive that fits it - try a search in this forum, that question pops up now and again - personally i dont like to carry anymore stuff about than I need to, and the PS has always worked for me. TNX is tempting tho - go for whatever u can get the most spares for, easily and cheaply, is my honest advice. |
if you want to look for a tiger drive system their site is [link]http://www.sullivanproducts.com[/link]
do u need to get a different pull start case for the tiger drive?
ZAC |
no all you do is take the pull starter off and bolt the tiger drive right on the the engine
Hey There. I might be able to help. I currently own 4 CEN MT2 Fun Factor's, All with various setup's. First, to answer your questions. The CEN MT2 with the factory pull start, usually starts up on the first few pulls. The factory pull setup is very durable, and I have yet to break one. Personally, I prefer the Tiger Drive Kit, using an electric 12v drill motor with the adapter shaft made for the Tiger Drive Kit. The Tiger Kit does take away most of the stress in starting up the MT2. In my experience of working with RC trucks, I have found the MT2 Fun Factor the best deal on the market. With top speeds up to 45mph, even faster with the installation of a OS .18 engine, the MT2 has much of the cat like reflex's and is mostly bottom heavy, which means after most small jumps and leaps, the MT2 almost always lands on its wheels.... amost always, :-). I highly recommend this vehicle. The Factory Pull Start works great, I have just found that during colder weather, you will need to be a little more patient, as it takes longer and more pulls to get it started. Hence, the Tiger Drive kit by sullivan products is my personal preference for most of my RC trucks. Sullivan also makes tiger drive start kits for XTM Mammoth, Traxxas Jato, HPI MT2, HPI Savage..... Most kits are around $20 to $30 dollars. You will need to purchase a $9 dollar HEX adapter shaft for your kit, that works on all tiger drives, except for the HPI models, which use's a different type of HEX shaft to start their engines. Basically the HPI engines rotate in the other direction, than most engines. Hey, hope all this info helps ... Good Luck on your purchase.....and welcome to the world of RC trucks....
My MT2 has broken a pull start cord but it was easily repaired and now is better than it was as I replaced the cord with special heavy duty Kite Cord.
Starts are now 2 prime pulls on the cord and 1 or 2 start pulls and its going |
| All times are GMT -8. The time now is 07:46 PM. |
