reverse; nemesis
Should the instructions have came with the reverse package. Or is there a download on haw to correctly install there reverse on a nemesis.
RE: reverse; nemesis
cen told me to download the reverse directions off of the genesis manual. So I did. 4 hours later I still have no reverse, been working on this all day. The directions suck they dont even come close to what the parts look like. And since the genesis has a three speed there are extra parts. Has anybody installed the reverse in a nemesis. I think that I'm missing a gear. The way they show to put it together the gears never change directions. The reverse gear that is added is on the same shaft a the forward gear and no gear even touches theh reverse gear? Check out the install directions.
http://www.cenracing.com/cars/genesis/manual07to12.pdf |
Don't know on the nemesis, or the parts, but when I had me LE transmission apart to fix the shift lever, it seemed like the only difference was the GS086 gear. That when the shift lever was in forward that it engaged the internal shifter and for reverse engaged the GS086 gear. But then again I don't have the nemesis, but let me know cause I might upgrade to the alumi GS008 transmission and put reverse in it.
| All times are GMT -8. The time now is 09:27 PM. |
