Steering servo??
Ok on my MT2 I pulled my steering servo apart to look at it. . . . .(I'm new wanted to see what it looked like inside). Well when i pulled it apart the bearing was on the topside, but i noticed the gears on the inside werent meshed together. I know there is a chance that this happened with me taking it apart, but I was wonder if anyone else has seen anything like that. Once I put it back together all gears matched, and steering seems to be more responsive. Just found that kinda interesting.
Tiny |
RE: Steering servo??
never heard of it doing that before, they usually should be meshed together pretty well.
Steering was doing great either way. . .till user error turned it into a fence post [:o][:o]
I'm guessing you don't have a servo saver in your car?
Nope, not even sure what one is
Tiny |
yes - its fitted as standard - its the knurled, screwy bit at the top of the right hand side steering post - screw it down to tighten and vice versa. the tighter it is, the more steering u will get, but run a higher chance of stripping gears in the servo.
| All times are GMT -8. The time now is 10:22 PM. |
