Tire problem on CT5
I am having a problem with 30mm foam tires on my CT5, the continueally wear on the inside, on closer look I realised it was touching my Tie rod, how could I remedy this problem without loosing steer control with wider tires to the back? |
RE: Tire problem on CT5
You would have to use somthing like longer CVD's in the back with some bearings as spacers.Prob not what you wanna do.I would try some 24-26mm foams with about 1-2 degrees toe in on the back and 0-1 on the front.
ok, thanks
As a workaround I have machined some hex shaped spacers(2 mm) and now the 30mm tires work without touching |
| All times are GMT -8. The time now is 08:40 AM. |
