Which Funfactor MT wheels
hi im searching for some new lighter wheels and tires for my MT and i thought about hpi Type 5 Truck wheels:
http://www.hpieurope.com/graphics/pa...43/3043_01.jpg and Dirt Bonz tires: http://www.hpieurope.com/graphics/pa...60/4860_06.jpg but the Dirt Bonz tires are too smal they have only 50mm width and 105mm outer diameter and my old tires had 75mm width and 135mm outer diameter! But i want only tires wich have a profile like the Dirt Bonz so i am thinking about the proline tires Square Fuzzie Thttp://www.pro-lineracing.com/prolin.../8099/8099.jpg Hole Shot Thttp://www.pro-lineracing.com/prolin.../8192/8192.jpg Bow Tie Thttp://www.pro-lineracing.com/prolin.../8196/8196.jpg but how big are they??? are they also too smal??? do you have any sugestions for other tires??? (sorry for bad english i am from Germany and please speak easy english) |
RE: Which Funfactor MT wheels
i dont think wheels will fit because different hex size but tires you can get on the stock wheel.
the hex sizes are not the problem i could get other hex 12mm, 14mm, 17mm, 23mm,
but do you think the savage dirtbonz on this e-zilla wheels will fit??? they are only 15mm bigger than the stock ff tires (i know that i have tu use a 14mm hex then and i know that the dirt bonz will fit on this wheels) [link=http://hbeurope.com/piw.php?partNo=hb61165-2&lang=en]http://hbeurope.com/graphics/parts/h...61165-2_01.jpg[/link] |
There is to much off set in the wheels to use on CEN's MT's. The only wheels in 14mm and 17mm that I am aware of that will work are the Stable Maxx's and the Imex Romulins.
rolland |
...and I would personally not go to a larger diametre than the stock (138mm) FF size. 15mm may not sound like much but at the very least with the short wheelbase of the FF they look IMO too big and with that extra rotating mass you are likely to break things easier/more often.
Keep looking for a tyre thats in the 110-135mm range on some stablemaxx wheels and you will be sweet. |
| All times are GMT -8. The time now is 06:16 AM. |
