MT2 shocks screw, and nut
Anyone else have issues with the stock screws that mount the shocks to the tower bending? Any solutions?
Tiny |
RE: MT2 shocks screw, and nut
You want part #FFS006. You will need metric screws to attach them to the shock tower, but I forget the size. I will see if I can dig up the size for you. If you have a screw kit, it's a common size in the kit. Here is a link to the part at CEN's website.
http://www.cenracing.com/cars/ff/ff/ffs006.jpg I have these and I have not bent one yet. |
Sweet thanks.
If you can find that size that would be helpful too |
I am 99% sure the screws I used are M3x8 hex screws. They are threaded so you don't need a locknut on them. On the first one I installed, I used blue threadloc. BAD IDEA. They are on there permanently. The rest I just tightened up securely and check them every now and them.
My screw kit is all mixed up or I would know for sure, sorry. |
Generally the shock tower screws for the fun factors and NX series are 3x24 Socket head screws. Unfortunately due to the longer screw, if you go off a really big jump and land wrong, it is possible to bend them.
With any RC Car landing a jump wrong at a really high altitude is likely to bend the shock tower screws. This is not a problem isolated with just the Fun Factor/NX series. |
I remember someone doubling up their shock towers, a while back now, seem to think they had them mounted front and back of the bulkheads with a screw running btween, if you see what I mean... that might help a bit. Its gonna happen though, as said above.
| All times are GMT -8. The time now is 04:38 PM. |
