CT5 steering servo
The steering on newly bought CT5 RTR is problematic. I would appreciate some help to get it fixed. The problem is that the wheels do not return to centre once once you let go of the steering wheel. You have to turn the steering wheel slightly in the opposite direction to straighten the direction of the car. This extremely irritating especially on a track. I have tried a new servo saver but this has not cured the problem. What do I do? Should I get another higher torque servo?
RE: CT5 steering servo
HEY GUY ,
BE SURE THAT THE STEEING WHEEL SCREW IN THE MIDDLE IS NOT TIGHT THIS COULD PREVENT THE WHEELS FROM RETURNING TO CENTER!!! I HAD THE SAME PROBLEM WITH MY GST. HOPE THIS HELPS |
Hi Tx for the response. This is not the problem though. I using alkalines for the receiver. Could it be that the voltage is dropping thereby reducing the effectiveness of the servo?
Any Ideas? |
| All times are GMT -8. The time now is 01:07 AM. |
