RCU Forums
-   CEN Racing (https://www.rcuniverse.com/forum/cen-racing-310/)
-   -   Servos....... (https://www.rcuniverse.com/forum/cen-racing-310/5588905-servos.html)
El Burro 03-20-2007 05:59 AM
Servos.......
I just went to hobbytown last night and bought a brand new O.S. .18 CV-RX for my MT2. But I would like to get a better radio sytem for it, does anybody know what hitec or futaba servos are compatible? I am clueless when it comes to that stuff :D
rolland 03-20-2007 09:08 PM
RE: Servos.......
Are you looking for servo's or a different radio?
rolland
cenracer1 03-21-2007 10:50 AM
RE: Servos.......
I run the hitech 645mg servos in my mt2.. I switched to the airtronics mx3 radio that cen offered as an upgrade... their stock radio is either the impact or skyon am.. I believe they are made by airtronics as well.. (I could be wrong)... I had to modify..(shave) off the ends of the plugs to fit... otherwise... direct replacement... futaba and hitech should fit as well...
s5lin 03-22-2007 01:10 PM
RE: Servos.......
Be careful of the polarity of the plugs before you just plug the servo into the RX. Futaba radio gear is generally different from Airtronics/Sanwa/Jr/Hitec for the wiring. The positve and negative leads are swapped for the Futaba versus that of the Universal or (Hitec/JR/Air) plugs. Also if you do install Futaba Servos and have the correct polarity, you will have to shave a little plastic off the Futaba servo plug to be able to plug the servo into the RX.
Hope this helps.
