RCU Forums
-   CEN Racing (https://www.rcuniverse.com/forum/cen-racing-310/)
-   -   Fun Factor Rally - Springs and Droop (https://www.rcuniverse.com/forum/cen-racing-310/6926479-fun-factor-rally-springs-droop.html)
gadorey 01-18-2008 01:40 AM
Hi,
Does anyone know if there are alternative springs for the FF Rally (harder/softer)??? If so, part Nr.s would be great.
If not from CEN, are there any others that fit? HPI or others?
Also, when I lift the front or rear axles off the ground there is no downward movement of the wheels/control arms - that means absolutely 0 Droop. I've tried messing arroung with the preloads, shock positions, etc with no effect. The springs just seem to be so stiff that there is no static compression. Is this normal, or am I missing something?
Any experiences would be great.
Cheers
gadorey 01-20-2008 09:56 AM
RE: Fun Factor Rally - Springs and Droop
No answers?
Come on CEN, how about some support for your products other than trucks, truggies and buggies
rolland 01-27-2008 12:28 AM
With the Rally's shorter shocks I suggest trying Losi XXX springs. You could also take your springs into your LHS and compare springs.
rolland
dustin7837 01-27-2008 10:38 PM
Exactly! Springs are pretty generic. Just find some that are the same diameter in a stiffness that you like...
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
