HAWK PRO GEAR PROBLEMS
Old 01-22-2006, 07:07 PM
Jamesrd
Default HAWK PRO GEAR PROBLEMS
Hello all, Just wanted to let you know what has hapen to me. Today I was out flying my Hawk pro for a test flight, and when I was hovering I lost total control of the tail rotor. After it hit the ground I looked at everything and noticed that the gear going to the tail rotor had came off. This is a piece that the manufature has assembled. Look over everything before you fly. I looked over everything incuding this. I noticed that the set screws did not have any locktite on them after the fact. Hope I help you all out.
Old 04-23-2006, 06:26 PM
rsrogers
My Feedback: (10)
rsrogers's Avatar
Default RE: HAWK PRO GEAR PROBLEMS
On first inspection mine had no set screws in it a all.
I have no complants though & it pays to do a MAJOR first inspection.
Old 04-27-2006, 08:06 PM
Gorgok
I never looked at mine, i must admit... I opened it up to spray in some tri-flow, but thats it. (Assuming you mean the tail end of the shaft, not the main gear portion.)
I probably should... but considering the many full deflection (both ways) inputs i have given it, it would have failed by now...
Old 01-23-2007, 11:40 PM
1fasthitman
The manual states that you should disassemble all components and check for screws without threadlock on them. You must have missed that part.
