again
RE: counter shaft loose again
Do the third bearing mod. Carve out the frame above the top bearing to accept another bearing. Then clean the shaft and inside of the bearings with alcohol and use red or green loctite to glue them togeather. Make sure you let it dry before you fly. At least a good 24 hrs. I think Steve H or The Wasp over on run ryder in the Century Forum have pics of the mod.
Kit or ARF? If it's the ARF make sure you take the tail apart and re-loctite everything. The drive pins have been known to come out causing catastrophic failure. But let me know how you like it. I might have an extra OS 37 here in a month or two and may pick up a Rappy 30 as a second bird.
Eric.
Eric.
