Hawk pro Starter shaft?
Old 01-23-2007, 10:20 AM
Flyer2k5
Default Hawk pro Starter shaft?
What starter shaft do I need to start the Hawk pro? Will this work http://www2.towerhobbies.com/cgi-bin...?&I=LXKZA2&P=0
Old 01-23-2007, 10:39 AM
DebianDog
DebianDog's Avatar
Default RE: Hawk pro Starter shaft?
Yep 6mm
Just double check the dimensions vs. your starter. I bought one and the shaft on my Sullivan was thinner than the hole. i.e. It does not fit! (if I want to mount it on the shaft)
Old 01-23-2007, 10:40 AM
DebianDog
DebianDog's Avatar
Oh the Century one is cheap too
http://www2.towerhobbies.com/cgi-bin...?&I=LXLMP7&P=7
Old 01-23-2007, 01:38 PM
syclic
From the descriptions of both, it seems the helimax unit for $19.95 is one with a built in one-way bearing. I would try to verify that, and IF SO, then I would get that one. Having a one-way bearing in the start wand hub is a big plus. If you try to start an engine that is a bit too rich, any "back-fire" forces will be nulified by the one-way bearing, instead of having to be absorbed by clutch/fan assembly in the helicopter.
IF it is a one-way start wand - the $19.95 price is 1/2 of anyone else. IF it is not a one-way unit (if that is a misprint) then it is much like the Century unit so I would take the Century unit and save the $2.00.
Old 01-29-2007, 10:25 PM
foresterxt
My Feedback: (35)
foresterxt's Avatar
I just picked up one of the $19.99 starter hex shafts. It does indeed have a one way bearing.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
