Hawk pro gallery
Old 02-15-2007, 10:38 AM
Nitrofever3D
Nitrofever3D's Avatar
Default Hawk pro gallery
Post pictures of your birds.
ID:	622157   Click image for larger version
ID:	622158   Click image for larger version
ID:	622159   Click image for larger version
Old 02-16-2007, 01:23 AM
nerv2112
nerv2112's Avatar
Default RE: Hawk pro gallery
Here is mine. Pretty much stock except for the carbon blades. I have been eyeing some of the aluminum parts though [sm=spinnyeyes.gif]. Now if the wind and rain would quit I could get her back in the air where she belongs.
Old 02-16-2007, 02:29 PM
syclic
Nitrofever,
Just a few comments from your pictures:
1 - I hope that where you have your gyro in the pictures is NOT where you plan to keep it for flying. I would suggest that you put it on the battery tray in behind the Throttle and collective servos (where the plans show the on/of switch to go). This will provide a much better platform for the gyro to work from. Then move the switch to the lower frames and attach it with double sided tape. This will isolate it from any vibes.
2 - Also note in the detailed instructions (not the quick build ones), that the two control rods that go to the aileron bellcranks are not mounted on a wheel that has them at 180 degrees to each other. Look at the instructions carefully and you will find that the balls for the ball links on the wheel used have both balls about 15 degrees forward of center. What you want here is a 90 degree angle between the control rod and the line that would go from the center of the servo wheel to the point where the ball joint is mounted onto the servo wheel. I find that using the standard plastic wheel (that does not have any holes in it, that comes with most servos) is best to use here. Then you can drill the 2mm hole for mounting the ball joints right at the ideal locations.
3 - Your picture show the collective servo arm at a position that is 90 degrees to the servo. I trust this is when your TX collective stick is at half stick. But then your center of the long upper part of collective arm does not look like it is parallel to the boom like it should be. It looks like your collective pushrod needs to be lengthened, such that the center of the long part of the collective arm is parallel to the boom. Then the collective pitch links to the blades should be adjusted to give 0 degrees collective when the software in the collective pitch curve in the radio at 50% at center stick.
4 - For training I would strongly suggest that you replace the orange bling paddles with the stock ones. They are much more stable in the hoer AND in FFF.
Old 02-18-2007, 03:39 PM
Nitrofever3D
Thanks but i think my heli is set right its been set at the field by a heli expert the head that is.Everything is centered.The gyro i just had put there before i took the pic since i was making a custom mount wich ill post pics of whe i get my heli back together.I actually lost my engine yesterday at about 200 feet and did my first auto and let me tell u for my first one it looked like ive been doin them for years.Reminder if any one get the Torpedo speed hv muffler make sure u use red thread locker on your optional nipplescrew hole i had used blue on mine and it vibrated off and had a chain reaction and lost my motor.Broken conecting rod, bent sleve and broken piston.Also before i forget the instruction dont actually show what your talking about if anything it talks about if u want faster response bring the links in on the sevo horns.
heres the exhaust http://www.heli-world.com/detail.aspx?ID=537
Old 02-21-2007, 02:40 PM
hvac
My Feedback: (7)
os 37, jr821, fut 9252, 401 gyro, eclipse radio, toki pipe
ID:	626612   Click image for larger version
ID:	626613   Click image for larger version
Old 02-21-2007, 04:21 PM
Nitrofever3D
I like the way your canopy looks
Old 02-21-2007, 08:35 PM
syclic
tlman
Very nice - and visible - would be easy to orient inverted and right side up.
Old 02-22-2007, 06:43 AM
nerv2112
nerv2112's Avatar
Mine looks like this now. I think a new paint job is in order this thing it too hard to see with all the gray skies we have here in the northwest when I get it way up there.
.."oh crap its inverted how did that happ.. . errrrr crash!" [X(] $$$$
Old 02-22-2007, 10:47 AM
Nitrofever3D
Damn.Here is some pics of the other day. If u notice i have half a tail fin i broke it practicing autos.
ID:	627228   Click image for larger version
Old 02-22-2007, 11:07 AM
coffeenut11
mine.
Old 02-22-2007, 07:13 PM
racer-RCU
My Feedback: (14)
heres mine......can you tell i want a scale body lol. and yes the light works hehehe
Old 02-23-2007, 06:21 PM
riddum
here is my heli
Old 02-23-2007, 08:57 PM
redneckteddy103
heres my setup ( im still learning to fly soo )
dx7
401 gyro
9253 for the tail servo
ds821's all the way
0 on the bottom and +10 on the top pitch range
and the last pic is the rest of the fleet
ID:	628316   Click image for larger version
ID:	628317   Click image for larger version
ID:	628318   Click image for larger version
ID:	628319   Click image for larger version
ID:	628320   Click image for larger version
ID:	628321   Click image for larger version
ID:	628322   Click image for larger version
Old 02-25-2007, 11:30 PM
credence
Damn, took me awhile to jump in on this thread . Here's some shots of my E-Hawk Pro sporting it's new paint job. Not my original desired color scheme, but a "mishap" with the airbrush forced me to..alter it..
ID:	630058   Click image for larger version
Old 02-26-2007, 10:41 AM
nerv2112
nerv2112's Avatar
ORIGINAL: racer-RCU
That is really awesome. I might even have to steal your idea. How did you make the rivets?
Old 02-26-2007, 08:45 PM
racer-RCU
My Feedback: (14)
the rivets are simply glue drops applied with a toothpick end....the paint on mine eventually just started peeling off so i had to make a new paint scheme just sumthin simple
Old 03-01-2007, 05:47 AM
nerv2112
nerv2112's Avatar
I am having the paint peeling problem as well so im thinking of redoing it again. Wonder if a good primer would help.
Old 03-01-2007, 07:32 AM
credence
I found the hawk canopy a real pain in the ass to paint.
You really need to scuff the canopy good, then prime it, then paint it, then use clearcoat.
Old 03-01-2007, 09:23 PM
syclic
credence,
You said "I found the hawk canopy a real pain in the ass to paint.". That is true of any current models that use this universal plastic type of canopy.
For my fancy painted canopies I use these. They are very light fiberglass units that come with a kight colored gel coating as a base. They are very easy to prep and paint.
http://www.heli-world.com/detail.aspx?ID=128
Old 03-06-2007, 03:19 PM
jester4
My stock looking Hawk, with it's big brother:
Old 03-06-2007, 05:28 PM
credence
ORIGINAL: syclic
credence,
What's funny is the canopy, in it's stock form, has a "rough" surface. I thought to my self "cool, I won't even need to scuff it before hand!"
WRONG! Paint peeled right off!
After scuffing the hell out of it, I got the paint to work quite well, but it wasn't easy.. [&o]
Old 04-25-2007, 10:55 PM
Cambo
Cambo's Avatar
New 10 pixel camera
Hawk pro .30
OS .37
qpcm
gy 401
9254 on tail
9252 on the collective
the rest is 3151's
heavy duty on/off switch
2500 mah battery
6.8 pound RTF
The only thing i have changed since the pitcures are a carbon tail tube and the gyro mounted to the rear.
This bird is awesome, it has taught me nose in hovering, auto's, FFF, and we will se with aerobatics (that is comming soon )
Oh, and i am running 1800 rpm head speed on funkey 550's with +11,-11 pitch. Insane power to weight.
Old 04-25-2007, 10:56 PM
Cambo
Cambo's Avatar
and more
Old 04-25-2007, 10:58 PM
Cambo
Cambo's Avatar
and finally
Old 05-01-2007, 08:24 PM
bigdad390
My wifes favorite spot for me to store my heli's
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
