Balancing Blades
Old 03-22-2007, 08:42 PM
Cambo
Cambo's Avatar
Default Balancing Blades
Both read 108g on the digital scale. Is that close enough or do i need a scale that will go another decmal place
Old 03-24-2007, 05:50 PM
syclic
Default RE: Balancing Blades
They should be close enough. Most Century ARF wood blades are ballanced well enough. The only time I even check them anymore is if after running up to speed there is a low frequency vibe. Then I will check. But haven't come across any that required further balance in years. Just be sure you have glued the plastic blade roots as the manual indicates.
Old 03-24-2007, 06:36 PM
Cambo
Cambo's Avatar
Yep, i used the CA glues as suggested.
Cyclic, i had some problems with the 9252 collective servo pushing the heli down at random times. It was only for a split seconds but am not sure what caused it. I have rewired to the best of my abilities and will try again tommorow. What could be the problem?
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
