Tail Control Pitch Plate
Old 07-06-2007, 01:20 PM
theLane
Default Tail Control Pitch Plate
Hi all,
Just building a Hawk 30 and the tail pitch control is tight and does not slide very easily. Anyone else have this issue? How did you loosen it up?
I initially thought it was the control rod, but after disconnecting it, the rod moves ok. Hooked up, I doubt the tail would be functional. I tried greasing it a bit and it helped somewhat, but still no luck making it smooth.
Any thoughts?
Lane
Old 07-06-2007, 01:53 PM
irc
Default RE: Tail Control Pitch Plate
Had the same problem with my hawk pro, the supplied tail control rod had too much "flex" in it, upgraded to the carbon rod conversion, available from century, sorted it all out
Iain
Old 07-06-2007, 02:41 PM
theLane
Thanks!
Old 07-06-2007, 04:30 PM
theLane
You mean this?
http://www.heli-world.com/CENTURYHEL...spx?ID=HW6065B
Does that come with everything I would require?
Where is a good source to order from? Any good sources in Canada?
~Lane
Old 07-06-2007, 04:31 PM
theLane
or this one?
http://www.heli-world.com/CENTURYHEL...aspx?ID=CN2264
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
