Go Back  RCU Forums > RC Helicopters > Century - Predator, Hawk IV, Falcon, Raven
Reload this Page >
Share your Swift 16 setup.....
Old 04-30-2009, 03:11 PM
67shelby
Default Share your Swift 16 setup.....
Hey guy's,
I asked this a couple of weeks ago with only a couple of responses... was hoping for a few more. I'm building my first large scale heli and was wondering what setups you used, liked (disliked???) for the Swift 16.
Motor -
ESC -
Servo -
Tail Servo (if different) -
Gyro -
Battery -
TX -
RX -
Misc. -
Thanks!
Old 04-30-2009, 04:52 PM
rotordoc1
Default RE: Share your Swift 16 setup.....
On Swift 16
Motor - Century 600+ with 11T pinion
ESC - Century 55A
Servo - Futaba S-3151
Tail Servo (if different) - S9254
Gyro - GY401
Battery - Flight Power 4S/3700 and 5S/3700
TX - Futaba 6EXH/2.4
RX - Futaba 6EXH/204
Misc. - I use a seperate RX battery 4.8V/2400 mah NiMh pack to drive the on board radio gear
Mainblades: Stock and Century Funkey 530mm grey composite mainblades
Swift 550SE:
Motor - Century 600+ with 9T pinion
ESC - Century 80A
Servo - Futaba S-9252
Tail Servo (if different) - S9251
Gyro - GY611
Battery - Flight Power 6S/3700 & 6S/4900 and Thunder Power 6S/4500
TX - Futaba 14MZ
RX - Futaba PCM148DP
Mainblades: Rotor Tech 515 or Rotor Tech 560mm
For scale you will want to set-up for a relatively lower head speed (related to the voltage of your battery pack, the KV of the motor you choose and the pinion you choose) then I use for 3D which will give you less aggressive and smoother cyclic and collective response and longer flight times.
Old 04-30-2009, 10:01 PM
67shelby
Thanks rotordoc1. One more question (actually I guess two), as a beginner I was told (for FP heli's anyway) to add some positive pitch into the flybar paddles. What about a basic pitch setting for a beginner. Basically just practicing beginner manuevers and hovering... NO 3D or anything aggressive. Also, I know this is going to make me sound really stupid but what is it people are referring to when you say "for scale you will want to..." What is "scale"?
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
