century next generation
Old 08-24-2009, 09:10 AM
zach123
Default century next generation
has anyone built the next generation heli and had problems with clutch and gear meshing?
Old 08-24-2009, 10:37 AM
rotorsport
rotorsport's Avatar
Default RE: century next generation
Are you asking about the 50 size or the predator 90 or gasser heli
Charles
Old 08-24-2009, 11:59 AM
zach123
50 size
Old 08-27-2009, 11:36 AM
rotor09
There are three NX50's at our club and no problem with gear mesh during assembly. They are great helis.
Old 08-29-2009, 10:55 PM
Furious Predator
No gear mesh problems on my NX50. the drive is also 100% identical to the original Raven 50.
re-check the assembly of the one way shaft that has the pinion on it and make sure you have the 4 brass washers in the correct spots.
make sure your engine is not sitting so low the clutch rubs on the gray gear, and not high enough for the fan to hit the shroud.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
