OS 61RF-P with unusual carb
Old 02-23-2018, 05:42 AM
Niall
Default OS 61RF-P with unusual carb
Guys,
Picked up a new Hanno MK1 (3034) and an 61RFP recently. The RFP has an unusual carb with standard throttle arm and a servo arm for what I believe is high end adjustment. anyone ever run one of these ?
Niall
ID:	2255649   Click image for larger version
ID:	2255650   Click image for larger version
ID:	2255651   Click image for larger version
ID:	2255652   Click image for larger version
Old 02-23-2018, 08:10 AM
do335a
Once had a 90 size Rossi fan engine which had exactly that sort of arrangement.
The arm on the high speed needle was for in-flight adjustment of the fuel/air mixture, as it is on your OS 61.
Old 02-23-2018, 03:22 PM
flywilly
My Feedback: (121)
Very nice engines (the Hanno is one of my all time favorites)! Yes, that carb on the RFP is for in flight mixture control. Seems a bit unnecessary on a pumped engine. I have thousands of flight on my Hannos (I keep a log) and the high speed needle rarely needs adjustment; only when there is significant atmospheric change. That looks like a two nipple pump on the RFP which is not original. The original had 4 nipples: fuel inlet from tank; fuel return to tank; fuel outlet to carb; fuel return from carb. Is the mixture control carb an OS carb? Or aftermarket? It looks very well made.
What airplanes are they going in?
Old 02-24-2018, 03:15 AM
Niall
Hi,
Thanks for the responses.
Its an OS carb and has 2 nipples on it. The seller spoke with Hobbico who say it was a rare "special" version made by OS before the Hanno arrived. I'm going to put the Hanno in a Summit made be Leo at BAC. Currently flying electric pattern but want to have a bit of fun with vintage pattern. It will be my first 60 two stroke since the 90's
Niall
Old 02-24-2018, 08:22 AM
flywilly
My Feedback: (121)
Hi Niall,
Thanks for the information. Can you post a photo looking into the exhaust port of the RFP, please? I am wondering if it has the porting upgrades of the Hanno without the red head.
Which Summit? 1, 2 or 3?
-Will
Old 02-24-2018, 07:21 PM
dhal22
Indeed they are nice. Great find(s).
Old 02-25-2018, 04:13 PM
doxilia
doxilia's Avatar
Will,
not sure what you mean. To me it looks like a standard four nipple RF-P pump unit. The Hanno naturally has the simpler two nipple pump unit.
David
Old 02-25-2018, 04:27 PM
flywilly
My Feedback: (121)
Yes,
I just glanced at the photos and didn't see the return line on the carb. I would now surmise that it is a stock RFP with the carb added after initial purchase. I have seen that carb on an OS 160FX running without a pump. Considering the price of that carb, whoever swapped it from the original would have been better to spend the money on a new Performance Specialties (Nelson) piston/sleeve. The version released for the RFP (prior to the Hanno) had some porting changes (especially to the exhaust duration) which added 400-600 rpm depending on prop used. The RFP in that configuration was pretty close to the Hanno in power.
I am amazed at the number of NIB Hannos still in existence!
-Will
Old 02-27-2018, 04:13 AM
RuneG
The oldest Version RF had 2 lines from pump to carb Hanno had 1 , the ekstra arm isnt that unusual its a meetring to adjust high end in the air , those times pretty helpful.
cant remember what the second line on the RF really was for ....
Old 02-28-2018, 11:11 AM
Niall
Hi Niall,
-Will
Hi Will,
Looks like the standard porting of the RF i.e no elongation of the port exit on top like in the Hanno. I'll try to get a photo up at some stage.
I'm going for the Summit 3. Leo at BAC has just finished the fuselage. Can't emphasize enough what great customer service Leo provides!!
Niall
Old 02-28-2018, 01:25 PM
flywilly
My Feedback: (121)
That will be a great combination. Ivan campaigned the original very successfully! Will you be going with Shamrocks in place of Maple Leaves?
Old 03-01-2018, 01:18 AM
Niall
Now there's a good idea
Old 03-01-2018, 05:26 PM
dhal22
Ha!
