Blue Angel - Build
Old 05-06-2015, 06:54 PM
  #1351
judgedredd
A Blue Angel 40 SR just went for $735.01 on eBay! That's the one I had my eye on. Did anyone on here buy it? If so congrats!!
Old 05-24-2015, 05:23 AM
  #1352
dhal22
Mike, a few views short of 200,000. Truly a compliment to your building skills and thoroughly detailed thread.
Old 05-24-2015, 12:14 PM
  #1353
8178
My Feedback: (17)
8178's Avatar
You are correct and thank you David. Only about 200 to go to make 200,000 views. That does seem like a lot of views for a build thread where only one person is involved with the build, plus the small community of Classic Pattern.
Mike
Old 05-25-2015, 05:11 AM
  #1354
speed-panzer
speed-panzer's Avatar
Just a real great build thread, and a true classic pattern plane.
Every once in a while I page through for one or other detail, to get an idea for oh so many small problems you come across your own projects....
Dominik
Old 05-27-2015, 03:10 AM
  #1355
dhal22
200,000 views. Wow.
Old 05-27-2015, 03:46 AM
  #1356
8178
My Feedback: (17)
8178's Avatar
I’m amazed that my humble little build Blue Angel build could accumulate 200,000 views. Many thanks to all of you that provided encouragement along the way as I was working though how to build the beast.
Mike
Old 06-06-2015, 11:51 AM
  #1357
martair
martair's Avatar
Cool Sunshine Blue Angel
Hi guys
For quite some time I have been keen on building a piece of history...something I was looking up to as a kid.
The Blue Angel cought my eye already a while ago.
I came across this thread and read all the way thru.
Just a few days ago I have set my eyes on the Steinhardt Red Devil, but after going thru this fantastic building log I realised
that the Red Devil is not quite a Blue Angel!?
What's more...there is still a lot to do!
The Blue Angel from Sunshine seems to be a lot closer, much more is done already...and hey, it's noch even much more
expensive the just the fuse, canopy and plans from Steinhardt!
To cut to then chase...I just ordered a kit!!
I am looking forward to receiving the kit and will get back once it arrived!
Thanks guys!
Cheers, Martin
Old 06-06-2015, 05:21 PM
  #1358
hook57
My Feedback: (21)
Sunshine? Are they still making the BA, and maybe the Curare? I picked up one of each at a swap shop earlier this year. The BA was on my wish list for a long time. The Curare has some differences, but hey, it's still smells of late seventies pattern! Meaning 10cc two strokes, pipes, retracts, 11X7 3/4 props on 5 or 10% nitro, and flat out speed......!!!
mark
Old 06-07-2015, 04:35 AM
  #1359
8178
My Feedback: (17)
8178's Avatar
Originally Posted by martair View Post
Hi guys
Thanks guys!
Cheers, Martin
Martin,
Here is a build thread where they modified it to look more like a Blue Angel http://www.rcgroups.com/forums/showthread.php?t=1395902
Mike
Old 07-23-2015, 01:49 AM
  #1360
martair
martair's Avatar
Hi guys
Does anybody know the original profile used on wing and stabs on the Blue Angel 60??
Cheers, Martin
Old 07-24-2015, 10:39 AM
  #1361
doxilia
doxilia's Avatar
Hi guys
Cheers, Martin
Martin,
a Japanese variation of the HQ aerobatic symmetric airfoils. Compared to HQ, MK classic foils have a slightly sharper LE entry but max thickness occurs at about the same point (~35%). Foil thickness is also often on the order of 14%.
In any case it's not a standard foil as far as I've been able to learn. If one were to use HQ, you'd be very close. I have.
David
Old 07-24-2015, 04:01 PM
  #1362
8178
My Feedback: (17)
8178's Avatar
The Blue Angel does have a really nice looking airfoil. It does not have the blunt leading edge that you see on some of the other 70s vintage aircraft.
Mike
Old 07-25-2015, 01:53 AM
  #1363
martair
martair's Avatar
Thank you guys for the info!
I realised that it must be something special, looks different from what I am used to.
I am planing to digitalise the plan I downloaded to CNC the parts to build a BA.
It is my aim to amend the construction in a modern way to safe weight. Thick balsa sheets to be sanded to shape
is certainly not state of the art anymore!?
As for the airfoil I am considering something more modern as well maybe!?
What do you guys think, should I rather use the original one??
To all the guys out there that own a Blue Angel:
Is there any washout in the wing?
Comparing the airfoils at the root and at the tip from the plans it seems that the thickness does not change and also that there is no washout!?
In the meantime my BA-kit from Sunshine Germany with the fibreglass fuselage and the foam wings arrived at my sisters in Switzerland and I will pick it up
in about 3 weeks. I am looking forward to inspect that thing, specially when it comes to the wing and its airfoils.
The weight of the kit will also be very interesting
Still not sure if on this model I will leave the more modern ailerons (named in here as barn door! ;-)) since this is acc to modern aerodynamic findings
the better option anyways!?
I might focus on a more original style on the second one which will be built in wood.
Also the question of the motor remains. On the first one I will most probably go electric.
Well...I will report again with news as soon as I have some :-)
Have fun flying guys!!!
Cheers, Martin
Old 07-25-2015, 04:36 AM
  #1364
dhal22
I think my BA is 8lbs, same short kit as this plane (foam cores) and I used contest grade balsa.
Old 07-25-2015, 08:12 PM
  #1365
doxilia
doxilia's Avatar
Martin,
it it is extremely rare to have washout in pattern planes. Washout turns into washin when inverted!
David
Old 07-30-2015, 06:08 AM
  #1366
8178
My Feedback: (17)
8178's Avatar
Actually the "barn doors" are old style and you will see them on the very old classic designs.
Old 08-03-2015, 04:35 AM
  #1367
bob27s
My Feedback: (19)
bob27s's Avatar
Just adding to the view count
Old 08-04-2015, 12:06 PM
  #1368
8178
My Feedback: (17)
8178's Avatar
Miss you at the Atlanta RC club Bob.
Mike
Old 08-06-2015, 04:26 PM
  #1369
dhal22
Bob weren't you away from RCU for a bit? If so, good to see you back around.
Old 08-23-2015, 02:33 AM
  #1370
Taurus Flyer
Taurus Flyer's Avatar
Originally Posted by doxilia View Post
Martin,
David
Just as differential for ailerons
TF
Old 08-24-2015, 08:10 AM
  #1371
eness76-RCU
My Feedback: (13)
eness76-RCU's Avatar
VERY apples and oranges. Differential is used to equalize the drag between the two ailerons during a rolling moment, thereby eliminating unwanted yaw that is inducing a "barrel" to the roll. They should truly be zeroed in the neutral position, so there is no wash-in/wash-out.
Old 08-24-2015, 10:59 AM
  #1372
8178
My Feedback: (17)
8178's Avatar
I usually don't use aileron differential on high performance pattern aircraft because when you fly inverted it provides the opposite effect than intended.
Mike
Old 08-26-2015, 04:25 PM
  #1373
dhal22
Good to see you post over here Mike.
Old 08-27-2015, 09:44 PM
  #1374
Taurus Flyer
Mike
In this thread the Blue Angel is the subject so it would be interesting to see the throws of the ailerons as it was designed in the past.
For my Taurussus I use a own designed (analog) mixer that calculates the throw of the rudder depending of aileron and elevator deflections especially for inverted figures. For slow roll and 4 point roll etc.I switch off the mixer.
Taurus Flyer
Old 08-28-2015, 04:07 PM
  #1375
dhal22
Taurus Flyer
And a great subject it is.
So powerful the modern radios are. I look at my uncle's sliding aileron/flap mechanism design from many years ago (aeronautical engineer) and thank the Lord I have a modern radio.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
