Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > Classic RC Pattern Flying
 Tony Bonetti's  Troublemaker Build Thread >
Old 05-11-2007, 07:19 PM
  #51
My Feedback: (47)
dave_anderson's Avatar
Default RE: Eureka Aircraft Troublemaker Build Thread
ORIGINAL: tommy s
Ray,
Is there a construction article on Bonettis Intrepid or is it just
a cover shot ?
tommy s
I have a friend who knows Tony Bonetti fairly well I think. Let me ask him if Tony would be interested in resurecting the Intrepid!
Old 05-12-2007, 07:59 AM
  #52
My Feedback: (55)
Thanks Dave, I would be very interested in plans for the Intrepid.
By the way, when I was building my original pattern ships back in
"the good old days" I used pre built wings I got from a company called
Glaskin and installed the retracts the same as you are doing on your
Troublemaker. Never had a problem.
tommy s
Old 05-12-2007, 08:32 AM
  #53
RFJ
RFJ's Avatar
Tommy s,
No plans in that issue - just a cover shot. I don't think Intrepid or Troublemaker plans were ever published so anything Dave can find from his contact would be very interesting.
Ray
Old 05-12-2007, 09:06 AM
  #54
My Feedback: (47)
My friend in Vegas sent Tony an email for me. We'll see what happens.
Old 05-12-2007, 09:11 AM
  #55
My Feedback: (47)
My friend in Vegas got word from Tony. I now have his email address and when I have time I'll fire an email off to him. Anyone have any other questions for Tony Bonetti? I'll make sure to tell him about this forum if he doesn't know already.
Dave
Old 05-14-2007, 12:47 PM
  #56
My Feedback: (47)
Got both gear wells done and joined the wing halves. Now I have to wait for the glue to set. I chose to use Gorilla Glue (Elmer's Ultimate Glue, same stuff) to join the wing halves. This may not be that standard, but I've had excellent luck with this stuff. As it dries, it expands into every gap and crevice. It's totally sandable and I have used it extensively on 40% airplanes. I will however, use epoxy to glass the center wing.
Going to go back to working on the fuselage. Going to work on the tank mount and servo tray mount. Maybe make a push rod for the elevators.
Old 05-14-2007, 06:12 PM
  #57
My Feedback: (47)
Here's where I ended up today.
Most of the wing work is completed. The retracts are straight (I was worried I'd get them crooked). Next I will sand the center wing, cut out an opening for the retract servo, install training edge, install front dowels and glass it.
Did some work on the interior. Installed at pre-fab servo tray. I offset it so I can install a pull=pull rudder setup. Throttle cable sheath is installer.
This thing seems heavy, but I could just be worrying.
I have a lot of final sanding in my future.
ID:	684549   Click image for larger version
Old 05-15-2007, 05:49 PM
  #58
My Feedback: (47)
Just spent some time doing some wing sanding and checking the alignment of the wing to the fuse. I don't know how I did it, but it's right on.
I'll tell you. I have a new found respect for you guys who built these planes back in the 80's. This is a lot of work... and a lot of feel it out as you go. I'm sure this is making me a better builder.
Anyway. The next few sessions are going to be fitting the wing and building a belley pan.
SAND SAND AND MORE SAND....YIKES!!!
ID:	685184   Click image for larger version
Old 05-17-2007, 10:03 PM
  #59
My Feedback: (47)
Big progress today. Got the entire retract system working, monted the wings and stabs. Last thing I was doing before I tired out was building up the belly pan. The incedence came out less that 1/4 degree different, wing to stab.
WILL SOMEONE REASSURE ME THESE PLANES ARE HEAVY? I'M WORRIED i'M BUILDING A BRICK!!! FEELS LIKE THE PLANE AS IT SITS NOW IS 3-4 POUNDS.
ID:	686537   Click image for larger version
ID:	686538   Click image for larger version
ID:	686539   Click image for larger version
Old 05-18-2007, 12:47 AM
  #60
Ready to fly weight should be 6~7 lb, so you are only half way there...no need to worry, couple of lb of engine and radio still leaves a lb for tank and covering, easy.
Evan, WB#12.
Old 05-21-2007, 02:29 PM
  #61
My Feedback: (47)
Well alright... here's where the project sits. I only have a little work to do on the ailerons, then a final sanding (hence the filler). Tomorrow I will clean up the garage from all the woodworking (messy) and get ready to cover this bad boy. I'm pretty happy with the way she turned out.
Dave
ID:	688854   Click image for larger version
ID:	688855   Click image for larger version
Old 05-23-2007, 05:01 PM
  #62
My Feedback: (47)
Worked for 6 hours today and got the entire fuselage covered. Not the best job I've done, but for a fun ballistic ship with a questionable life span, I'm satisfied.
Colors are Metallic Plum Monokote, Orange Monokote, Platinum Monokote and White Ultracote. The canopy is Pearl Blue Monokote. That canopy area was like covering a football!!! Next I'll cover the wing and proceed with the home stretch!
ID:	690175   Click image for larger version
ID:	690176   Click image for larger version
ID:	690177   Click image for larger version
Old 05-23-2007, 09:27 PM
  #63
rainedave's Avatar
Dave, I love the colors you chose. It's a great looking model.
David
Old 05-25-2007, 06:52 AM
  #64
Dave,
I agree with rainedave, awesome looking model. Can't wait to hear a flight report.
Fly safe and have fun!!
David
Old 05-25-2007, 07:18 AM
  #65
My Feedback: (47)
ORIGINAL: hrrcflyer
Dave,
David
Appreciate it fellas. It may be a few more days before she's done. Life has once again gotten in the way.
So... you would say this plane looks "ballistic" enough? hehe Heck I still have a Tiger Tail 4 with Rossi .67 to refurb after this one!
Dave
Old 06-01-2007, 01:58 PM
  #66
My Feedback: (47)
Default RE: Tony Bonetti's Troublemaker Build Thread
Sorry for the delay guys. Life is still in the way.
Dave
Old 06-01-2007, 02:38 PM
  #67
My Feedback: (18)
Wow that is Cool...Neat looking colors!! Great scheme...
Have Fun...
Chuck
Old 06-08-2007, 09:09 PM
  #68
Any news? Is it finished yet? I ordered one from Don today, anxious to hear hows yours is doing.
Todd
Old 06-19-2007, 02:59 PM
  #69
My Feedback: (47)
Sorry, no news. My kids are here for their month long visitation and I'm trying to spend as much time as possible with them. I'm going to try and squeeze in finishing this before I HAVE to start working on a project finishing a guys 39% Dalton Extra 300. After all, he's paying... hehe
Old 07-08-2007, 12:52 PM
  #70
My Feedback: (47)
I'M BACK!!!
After a long break starting with an IMAC contest, followed by a month-long visit from my kids I'm back in the shop.
Got the internal gear installed and covered the bottom of the wing. I still have to get the throttle hooked up, re-install the retracts and make a simple mount for the pipe on the belly pan (going to use a spring).
Hope to finish covering the top of the wing today.
ID:	718330   Click image for larger version
ID:	718331   Click image for larger version
ID:	718332   Click image for larger version
Old 07-08-2007, 06:46 PM
  #71
My Feedback: (47)
Got the wing covering finished and put the retracts back in. Also did the throttle hookup. All that's left are the aileron servos and a few small things. Getting close!
ID:	718516   Click image for larger version
ID:	718517   Click image for larger version
ID:	718518   Click image for larger version
ID:	718519   Click image for larger version
ID:	718520   Click image for larger version
Old 07-09-2007, 04:16 PM
  #72
I really love your trim scheme Dave! Keep it going, we're all waiting for a flight report!
FB
Old 07-09-2007, 04:58 PM
  #73
My Feedback: (47)
I will add some sweet graphics after the first flying day with it. It's going to be smokin!!! My first BPA bird!!! I need to get a BPA logo so I can give it to my graphics person.
Thanks for the kind words!
Old 07-18-2007, 12:49 PM
  #74
Excellent job on the build Dave. If someone was to have less build skill than a parrot, ie me, is there redemption in the form of an ARF for this aircraft?
Old 07-18-2007, 01:05 PM
  #75
locolobot's Avatar
Thought I would share with you the results of my efforts on a Troublemaker also. Decided to make mine with tricycle gear and fixed since I am in SPA and will be competeing there. A lot of them were not pqarticularly impressed that the Intruder ARF was orange but since I am a Tennessee fan you can understand the trim scheme. I would like to say it came in at 7 pounds 9 onces with a Magnum 91 as the engine of choice.
Jack
SPA 306
ID:	725403   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
