i have a fbg fuselage elle ?
FL
I have this old fbg fuelage did have foam wings some time in past but they did not last in the shed in the heat was wondeing if any one could id this fuselage it is 4'3' give or take long look at photo thanks for any help
RE: i have a fbg fuselage elle ?
A picture would help. [sm=wink_smile.gif]
You must upload the picture to a file uploading site and paste the link between the [ image][/ image] brackets.
AL
I am going to go with the Tipo. As I remember the Illusion had a full length belly pan that was intended for a rear exhaust tune pipe set up.
My Feedback: (57)
The difference between the Tipoare and Illusion is the wing saddle are. The Illusion moved the wing higher in the fuse. Here is a picture borrowed from this link. http://www.rcuniverse.com/forum/m_38...tm.htm#4035049
