anyone building a king kobra?
Old 12-31-2007, 06:42 PM
  #51
My Feedback: (18)
Default RE: anyone building a king kobra?
Good Looking work David...
Have Fun...
Chuck
Old 01-18-2008, 07:53 PM
  #52
When you said you glassed with Minwax, are you saying you used the minwax in lieu of either epoxy or polyester resin to soak the glass? I have a King Kobra that I'm interested in doing something similar with, and would like to glass the fuse- like you, mainly for building practice. I have a whole gallon of West Systems laminating epoxy and 206 hardener though, so I didn't know if I should use this or not. Did you glass over the plastic turtle deck, or just the balsa? Did you glass the wings and stab as well? I was thinking finish the fuse, then paint it with one of the Topflite polyurethane paints, then cover the wing, horizontal and vertical stab with matching Monokote.
Old 01-18-2008, 10:42 PM
  #53
yes, i sealed the fuse with sanding sealer, sanded and wiped clean with tack cloth and then layed down 3/4 oz fiberglass cloth and painted it with Minwax polycrylic. it dries in 20 minutes or so and then you can paint it again. sand smooth after 3 coats and repeat; paint 3 times and sand. after about 8 coats the glass weave has been filled in and you are ready for primer. since this is a water based finish, almost all of the weight evaporates. i have since noticed that someone on this forum was wet sanding, i've tried it and it works well. also, i have been told that you can add babypowder to the poly as a way to fill in the weave faster. i will try that shortly. after a coat or 2 of primer i use bondo spot putty to fill in any imperfections and prime again. almost all of the primer sands off, so there is very little weight gain. i should be in the primer stages this weekend and will post photos.
david
Old 01-19-2008, 01:00 AM
  #54
How did you deal with the plastic turtledeck? Did you glass over that?
Old 01-19-2008, 07:11 AM
  #55
sorry, i forgot you asked about that. i went ahead and used it as they showed. i just needed to move ahead with the project. i thought about that part for a long time. usually i rely on others for great ideas. i used ca glue for the complete installation. i leaned the fuse over and slowly drained thin ca under the deck onto the 1/8 strips. i am thinking about using epoxy/microballoons or bondo spot putty to fillet out the seam. i did all of this after i finished glassing the fuse.
david
Old 01-19-2008, 04:32 PM
  #56
Cool, thanks for sharing. I wasn't sure if you could glass over it or not. So, the minwax, this is just a can of the stuff you get at Home Depot? Specifically which minwax product? I've noticed they offer a "sanding sealer." Was that the one you used, then followed it up with another type of minwax? I'm assuming since this is water based, it's lighter than finishing/laminating resins, and now most people are using that now instead? How will it tolerate fuel? I apologize for all the questions, I've just finished reading all the Harry Higley's finishing books, and they're kinda out of date being published in the early 80's so I'm trying to get caught up with what you guys are all doing now.
Old 01-19-2008, 04:39 PM
  #57
please, i am not an expert. there are many many threads here and elsewhere that show this way of covering. and yes, the MInwax Polycrylic is in the stain section at you favorite home improvement center. it is the water based. there is also a oil based, you don't want that. the water based is in a blue can. whil you are there pick up some foam brushes. you can rinse them with water and use them many times.
with recent researching i have decided to do add the baby powder in 1 can and keep the other for thinning if i get the 1st can to thick.
david
Old 01-19-2008, 05:57 PM
  #58
Guys, be sure you seal the balsa with something before using minn-wax to adhere the cloth. If you don't, since its water based it will warp the wood like you wouldn't believe. Otherwise it works fine, sugarfox
Old 01-19-2008, 06:10 PM
  #59
yes, i had said to use sanding sealer 1st. along with a light sanding afterwards and a good dust removing with a tack cloth. THEN you begin to apply the glass cloth and polycrylic.
david
Old 01-30-2008, 01:35 AM
  #60
ORIGINAL: sugarfox
With all that to be concerned about, why not just use polyester resin?
Old 01-30-2008, 06:21 AM
  #61
it it so easy to cover my plane this way i don't plan on trying any other way. the 1st time i tried it i was amazed at how smooth the primered finish was. i did the monocote when i was in the hobby yrs ago but always wanted a painted finish. i finished a long ago framed super sportster last yr in fiberglass and koverall this way and was very happy. btw, it still sits primered and ready to paint. it will be a practice paint plane just like my KK when i get them both ready for paint.
david
Old 02-02-2008, 08:21 PM
  #62
blatantly borrowing ideas from a much more accomplished builder than i, i have use 6 oz. fiberglass cloth strips to form my wing fillets. i used a tape base to protect the rest of the fuse and have painted the strips with fiberglass resin. i replaced the rough tape edging after drying and sanding to shape with a more form fitting strip of tape. this will form the fillet fill in shape and protect the fuse during sanding. i want to go with fiberglass resin and micro balloons fill in but i am at a loss as how to apply the mixture to the fillet base. any suggestions?
thx, david
ID:	868402   Click image for larger version
ID:	868403   Click image for larger version
ID:	868404   Click image for larger version
ID:	868405   Click image for larger version
Old 02-03-2008, 07:29 AM
  #63
WEDJ's Avatar
ORIGINAL: dhal22
thx, david
Apply w/ popsicle sticks, then use your finger dipped in thinner to smooth it out. Make it as smooth as possible while it is soft, it's a B**ch to sand when cured.
Old 02-03-2008, 07:36 AM
  #64
i assume fiberglass and microballoons are going to be easier to sand than epoxy and balloons. i need to do a trial run of bondo spot putty. would be easier to sand.
Old 02-03-2008, 08:56 AM
  #65
My Feedback: (17)
8178's Avatar
Microballoons sand pretty easy. I use epoxy glue or polyester resin depending on what I’m putting it on. Just get it formed pretty close to what you want before it sets. I usually use a couple of coats with sanding in-between to build it up in layers.
Old 02-03-2008, 09:16 AM
  #66
great tip! i feel a lot better about building it up slowly. i'll give it a shot.
Old 02-07-2008, 04:02 AM
  #67
I have a chance to buy one from an individual and am about sure to do so. However, I need to know where to put the c.g. and the throws. Any info would be appreciated.
Ran
Old 02-07-2008, 05:24 AM
  #68
the cg, according to the build manual is 5 and 5/16ths inches from the leading edge. no more than an additional half inch further back should be considered in the event you want a more aerobatic setup. the throws call for: elevator - 9/16ths up and down, rudder 1 5/8ths and ailerons 1/4" up and down. let us know how she flies.
david
Old 03-09-2008, 08:08 AM
  #69
a few updates on my not a real pattern plane build. at least the building has a lot of similarities with pattern planes. i glassed the wing with .75 oz cloth and Minwax polycrilic but i picked up a tip that i used since i glassed the fuse. after laying down and coating the glass with polycrilic i added baby powder to the polycrilic as a filler. then the poly filled in the glass weave so well i was ready for primer before i knew it. keeping the poly wet sanded between coats left the preprimed surface extremely smooth. i then shot a thick coat of filler primer and wet sanded that. i was tempted to leave the wing there but i have since went back and spot puttied some imperfections. so far i have 2 oz of weight build up of poly and primer. this measurement is after i layed the cloth down with 1 coat of polycrilic.
ID:	898725   Click image for larger version
ID:	898726   Click image for larger version
Old 07-07-2014, 12:43 AM
  #70
david
David sorry about jumping in to your build I was interested in the sealer you used is that also the Minwax brand?
Old 07-07-2014, 02:29 AM
  #71
Yes Robert. I used a Minwax water based sealer. It works very well.
Old 07-07-2014, 02:41 AM
  #72
Thanks for the rapid reply, I have all three (kobra,kogar,and in the framing stage on this one) I gone back and forth with the finishing resin and the polycrylic See the Great planes F4 build he used a brand called Envirotex the water clean up seems the way to go. I did not recall if you mention that you have completed yours or maybe I missed it (I read and re-read just about everyone of the builds.)
Thank again;
Robert
Old 07-07-2014, 02:47 AM
  #73
I finished mine and flew it a few times. It had a rough dead stick landing and I retired it. Please show us your KK here or in your own thread.
Old 07-07-2014, 03:17 AM
  #74
I will it has had some down time as my Spring Air retracts were leaking so they are being rebuilt I'm told they were 20 years old. I did not want to skin the wings until I was sure they were working correctly. and about the same on the fuse need the nose gear. I will shoot some shots when I am a little further along and maybe I can get all 3 in. The little guy came in a bit heavy as I used regular servos on this one I will end up removing them and going back to the mini's I had in the first one. I met it's doom when the battery shifted and came unplugged at take off, when it went in I had to dig it out the spinner it was embedded about 8 inches needless to say not repairable along with most of the servos battery receiver had to hit well over 120 mph! The Supertigre G34 broke the needle and exhaust stack nothing else. Says something about good Metallurgy.
Again thanks for your help!!!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
