Ah, another G60 Bluehead...
I just opened the box and examined the ST G60 Bluehead that I bought off eBay a while back. With all the variations that are available, I got lucky and received the exact model that I have been using for twenty years (bought used from a friend). This one has a flat piston with a chromed liner and a piston ring, but not a Dykes ring. It feels great, but needs an antifreeze bath and some freshening up with a tooth brush. Not bad for $60.
The cylinder head is absolutely pristine. No scratches in the blued finish. Not even a smudge. The engine feels really great when turned over. Too bad that not a single new engine feels that good today (ringed, that is).
I'm smiling.
Ed Cregger
I'm smiling.
Ed Cregger
RE: Ah, another G60 Bluehead...
i have a nib hanno special that saw a lot of exposure over the yrs, the engine was mounted. i would love to clean it up a little but would hate to damage it in any way. would this way or the dawn power dissolver be the better way?
thx, david
thx, david
My Feedback: (8)
The antifreeze/crockpot method works very well...you don't need to get it hot though, just warm, say 100 degrees or so and that will not cause any discoloration, except to anodized parts. Just be sure to remove the head first or it'll probably come out pink...
I've been wanting to try the Dawn power disolver but can't seem to find it around here? If you try that method, don't leave it on for long though, just a few minutes, because (from what I've read in other RCU posts ) it can cause discoloration.
My Feedback: (55)
Ed,
Just a little info for you. It doesn't say it anywhere but the current ST .60 ring
will fit and work in the Bluehead. I resurrected an old Bluehead that needed
freshening up badly but couldn't find a ring anywhere so I thought I would just
give it a try and the new style ring fit and worked perfectly, compression restored !
Good luck
tommy s
Good luck
tommy s
QC, CANADA
David,
I'd also be concerned about the backplate pump on the Hanno in antifreeze (hot or cold). I've been trying to overhaul the used Hanno I bought but someone had the idea of using red thread lock on the BP bolts . I've been staring at it wondering how to loosen the BP without damaging the pump. I'm also not sure how the standard SF/RF drive washers, which look like they're anodized aluminum, will respond to antifreeze.
Any thoughts from the antifreeze experts?
Thanks, David.
Thanks, David.
ORIGINAL: proptop
You have me worried about not finding the Dawn Power Dissolver. I haven't had to buy any since my original two bottle purchase. I'll have the wife look around. Who knows, maybe it isn't being sold any longer. I hope it is.
Ed Cregger
IN
Ed, do try the Dawn product. I used it on a fairly cruded up piece that had been laying around for a long while and after 2 applications it looked as new as it could. Like others have mentioned don't leave it on long. I think I lift in about 15 min or so and scrubbed under hot water and had an excellent result. By the way, hows the Banshee coming ??????? regards Sugarfox
I was one of the original advocates for using Dawn Power Dissolver a few years ago. Don't remember? No matter.
Yes, it does work great and it will get rid of baked on castor oil with a little effort and repeated applications. I use it when an antifreeze bath is not warranted (not enough engines to cook).
Ed Cregger
Ed Cregger
Here's a couple of pics I took a while back when there was some discussion about baffled pistons in ST 60 Blueheads, but I never got around to posting.
I'm not much of a camera man, I don't think you can even see the baffles in either pic.
ORIGINAL: Blendzall
Do you know when that engine was made, approximately? I'm still trying to figure out the models/options/years of production of baffled and non baffled G60 engines.
Ed Cregger
My Feedback: (43)
ORIGINAL: doxilia
David,
Thanks, David.
David,
Thanks, David.
ORIGINAL: Ed Cregger
Ed Cregger
ORIGINAL: Blendzall
Ed Cregger
