Mama Mia by Joe Birdi
Old 04-15-2009, 04:35 PM
Johnkpap
Johnkpap's Avatar
Default Mama Mia by Joe Birdi
Hi I have Just bought a copy or the Mama Mia plan my Joe Birdi, It is a model Builder Plan
Looks easy to build and designed for a R E Engine does any one have a copy of the Issue it was
in or a Index with Year/Date so I can track down one.
Thanks in Advance
Old 04-15-2009, 05:23 PM
rainedave
rainedave's Avatar
Default RE: Mama Mia by Joe Birdi
I have the article. I can scan it and email it to you. PM me your email address.
Here is a composite image I made a while back comparing the size of the Dirty Birdie fuselage to the Mama Mia, Quite a difference!
David
Old 04-15-2009, 07:11 PM
Stuart Chale
Didn't this end up being the XLT?
Stuart
Old 04-15-2009, 07:21 PM
rainedave
rainedave's Avatar
This plane is much larger than the XLT. It has a very different wing planform, too.
David
Old 04-15-2009, 07:23 PM
Stuart Chale
Do the plans have a date? Was this before the XLT or after?
Stuart
Old 04-15-2009, 07:45 PM
buzzard bait
From the plan number, November 1980.
Old 04-15-2009, 09:57 PM
Johnkpap
Johnkpap's Avatar
It should make a good model to take a OS 61 RE also there is lots of room in the Fuse for a big fuel tank and retracts.
Well that is my plan for this model : the other option is to fit a Super Tigre 90 with a pipe it would be balistic.
I am in the procces of gathering supplies before I start to build one. The build should be no harder than a Super Kao's.
Johnkpap
Old 04-15-2009, 10:12 PM
MTK
ORIGINAL: sc204
Stuart
Several years before. Back then, we were using too thick balsa stocks and models of this size practically always came in heavy. Overbuilt .... I don't think many were built. Never saw one in the southwest pattern circuit which back then was more active than anywhere in the states. Contests typically had 50+ contestants (some 70+) and of all those models, no mama mia
With today's techniques the model can be made much lighter. It is quite large and should be a decent flier
MattK
Old 04-15-2009, 10:21 PM
rainedave
rainedave's Avatar
I bet an AX 1.20 would be a good match.
I've scanned the article. If anyone else wants a copy PM me your email address (never post your email address where it can be harvested).
David
Old 04-15-2009, 11:26 PM
Roary m
My Feedback: (67)
Would the Giant Dirty Birdy from Blue jay Models be the same ship as the Mama Mia?
Old 04-16-2009, 03:42 PM
Johnkpap
Johnkpap's Avatar
Thanks David for scanning the article
I will be starting to build one soon
Johnkpap
Old 06-23-2009, 02:52 PM
Johnkpap
Johnkpap's Avatar
Look What the Mail Man Delivered today ......
Everything can be found at the right price if you look hard enough
Johnkpap
Old 06-23-2009, 04:24 PM
rainedave
rainedave's Avatar
Is that a Super Tigre pipe? I have an ST side header. The ID is too small for a Mac's 3/4" pipe. It's about 19mm (.748")
David
Old 06-23-2009, 05:18 PM
Johnkpap
Johnkpap's Avatar
The pipe is a 90 size Super Tigre Pipe NEW Old Stock
The OD with the Length Adjuster is 15/16 inch /24mm
With out the adjuster it is 13/16 of a inch 20 mm My My Macs Header is also 3/4 of a inch A Close fit
If I use the Adjuster pipe I have to use a bit of smaller tube over the Mac's header to make it bigger.
Sorry Dave that header is possibly too small for my Super tigre 90
I am looking for the 90 size header / the Mac's will fit and do the job but not the best choice
http://www3.towerhobbies.com/cgi-bin...?&I=LXFV96&P=7
May also work but I think it should read 13/16 of a inch not 13/32 !!!![]
I am going to power a Mama Mia with my ST 90 side mounted, pipe through the top or along the side.
.....Will have to finish the arrow first... and find more bits first... I need to build a electronic controller for the Retracts!!!
Johnkpap
Old 06-23-2009, 09:39 PM
roncoleman
My Feedback: (14)
JohnKpap, That header bolts onto a ST-90S perfectly.
It might do the same on your engine.
Ron
Old 06-23-2009, 09:40 PM
anuthabubba
My Feedback: (102)
Johnkpap,
You might want to check out the MACS 2970,1,2 series headers that are 7/8"-22mm OD if you need the larger diameter. They are also about 3" longer.
Terry in LP
Old 06-23-2009, 09:55 PM
rainedave
rainedave's Avatar
ST has not changed the muffler bolt spacing since the G.60 came out in the late sixties (the older one-piece case V60 has the same spacing as the current .40, .45 and .51). The .61 through .90 all have a 47mm spacing. But, I didn't mean to cause any confusion; my header isn't for sale, I was just "sharing" pictures.
David
Old 06-23-2009, 10:16 PM
rainedave
rainedave's Avatar
I was just looking over the MM plans. The sides are 58.375" long and no seam/joint or splice is shown on the plans. Were 5' balsa sheets available back then? Today, you will have to splice together 48" or 36" sheets.
I pasted an OS .61FX onto the plans (because that's the drawing I had handy) to see how small it would look in the nose. Most .90's today are in .61-size cases, anyway. Or, rather, most current .61's are in 90-size cases.
David
Old 06-24-2009, 04:21 PM
Johnkpap
Johnkpap's Avatar
Thanks for the input David
I should have no problem fitting any thing in this plane, even the Giezendanner Retracts are BIG !! any one else
tried them before ? I am building up a Control unit to operate them via a RX channel direct the instructions sugest using a toggle switch and a servo
I think I can build someting less crude than this, I even have a old AM RX case to put in, if possible I will build i in or two fail safe's into the design
so if the cct fails the retracts come down and run them off a diffrent RX Pack
I Think Only a Crazy Aussi like me would build this one.....
Johnkpap
Old 06-24-2009, 04:44 PM
doxilia
doxilia's Avatar
Guys,
is this huge Dirty Birdy supposed to be flown on a 90!? [X(]
It strikes me more as a 120 AX bird. What's the span and weight?
David.
Old 06-24-2009, 05:22 PM
rainedave
rainedave's Avatar
The original was flown with a Webra 1030 .61 RE.
David
Old 06-24-2009, 08:23 PM
doxilia
doxilia's Avatar
Mmm... must be a 9 pounder at least.
How about one of these (1039CP)? Nice Dynamix!
David
Old 06-24-2009, 08:27 PM
doxilia
doxilia's Avatar
ORIGINAL: rainedave
David
I rest my case... the Webra 80 does look like a cool engine though. Almost as cool as my RE 12!
David, would you mind firing me a copy of that article? (I'm pretty sure you've got my address)
TIA, David.
Old 06-24-2009, 08:42 PM
doxilia
doxilia's Avatar
ORIGINAL: Johnkpap
Johnkpap
John,
those look like a nice set of Geizendanner electrics. Did you order them directly from Germany/Austria, the US or does someone in Oz carry them? How much coin?
I believe my next big pattern bird will be a 6 footer. I'll probably install a nice set of NOS Krafts (if they ever arrive... [])
What's up with RCU... are we back now to the old format for posting?
David.
Old 06-25-2009, 03:20 AM
Johnkpap
Johnkpap's Avatar
Hi David
The nice Retracts were bought on E&@y Auction For $19.50 Plus Shipping from Japan, they sell new for 200 Euro [X(] they are old model shop stock never been used, I just have to build a control unit that is a bit better than a two way switch linked to a servo.
The nice 90 pipe also E&@y Auction for 18.00 Quid from the UK
I have been looking for both of these for a few months, the turned up in the same week !!! I can start a build after the Arrow is finished, I am really getting a bit sick of sanding and sanding ......It better be worth it .... this arrow thing better fly nice.
You can buy them new at http://www.rewomodell.de/
Sorry the site is in german
Johnkpap
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
