RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Has Spring Air Improved (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/10570928-has-spring-air-improved.html)
BullardRM 06-13-2011 03:09 AM
Years ago I used Rohn Air retracts. I had both firewall mount and belly mount nose uinits. Both would wollow out the pivit block. This was due to a steel strut in a alunimum block. If memory serves me correctly, someone offered a teflon sleve that would isolate the two materials, solving the problem. Has this problem been solved in the new systems that are avaliablei.e. Spring Air? Way am I askingI plan to purchase a new set of gear.
summerwind 06-13-2011 04:33 AM
RE: Has Spring Air Improved
ORIGINAL: BullardRM
you won't be dissapointed.
i remember Rohm Air. SA pivot blocks are supported by a steel shaft, and don't wollow out.
KLXMASTER14 06-13-2011 10:09 AM
Spring-Air is a giant improvement over the Rohm-Air.
