RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Webra 61 Muffler (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/10718246-webra-61-muffler.html)
Patrick F 09-15-2011 12:56 PM
Webra 61 Muffler
Anybody know where one can get mufflers for this engine i need the strap type??
Thanks Pat
edwarda10pilot 09-15-2011 07:20 PM
RE: Webra 61 Muffler
Pat:
Might try Macs Products (they make mufflers and tuned pipe systems). If this doesn't work try Model Engine Corp of America (www.mecoa.com)
Ed
Johnkpap 09-15-2011 07:37 PM
Hi Pat
There were alot of Strap-on mufflers out there once that would fit....A new HP 61 muffler from MECOA will fit
I got a box of mufflers at the last local Club Swap/Auction for $20.00 and there was a number of odd ball mufflers that fit
just keep your eye out.
Also ask around your local model club someone will have one.
.....I would happy to swap one for a copy of a Direct Conection Ultimate Kaos Plan or Kyosho 40 Chipmunk Plan, I will even pay the postage from Australia for you :D
Regards
John
turbo.gst 09-16-2011 12:20 AM
Check with BCM ( Bisson Custom Mufflers / Canada). They offer several clamp on mufflers. I have had great luck using the Sport and low DB Sport. One other option is to tap the case on your Webra. The ones I have that are tapped use the OS #744 muffler bolt pattern. You might also look at some older Hobby Shop like Sheldons Hobbies and catch some old stock. That auction site is another good place to find a original clamp on.
ChiefK 09-16-2011 01:26 AM
Pat,
I recently bought a MACS "universal" strap-on for my Webra Speed .61. It works well. The only problem is that the Webra exhaust opening is not milled smooth, so I get a little exhaust leakage around the fit. I'm going to try making a gasket from automotive (heavy) gasket material to see if that seals it up a little better.
ChiefK
SuperViking 09-16-2011 06:06 AM
On flea bay all the time .
Patrick F 09-16-2011 07:46 AM
Gentleman as always thanks for your help.
Pat
Lasercut USA
gkaraolides 10-08-2011 11:37 AM
Hi,
ORIGINAL: Johnkpap
I can now confirm this. I ordered the strap-on silencer for the HP61 Silver Star part no. 30-2201 from MECOA. It has arrived today and it is a perfect fit for my Webra Speed 61 (1024).
I only have a couple of points to note. One, they could have blown the aluminium swarf out of it. Two, the screws that hold the strap to the silencer aren't M3 to match the rest of the screws on the Webra. They appear to be a non-metric size. I wonder if they've also changed the rest of the screws on their versions of the HP engines to non-metric sizes.
Best regards,
George
ChiefK 10-08-2011 01:50 PM
ORIGINAL: ChiefK
Pat,
I recently bought a MACS ''universal'' strap-on for my Webra Speed .61. It works well. The only problem is that the Webra exhaust opening is not milled smooth, so I get a little exhaust leakage around the fit. I'm going to try making a gasket from automotive (heavy) gasket material to see if that seals it up a little better.
ChiefK
My Deception is ready to fly again and I did cut a gasket for the joint between the Webra Speed .61 exhaust stack and the MACs Universal muffler adapter. I'll report how well that works after I get out to the flying field again.
ChiefK
