RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Fixed gear Pattern Planes (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/11330280-fixed-gear-pattern-planes.html)
jog0723 12-13-2012 10:32 AM
<![if !mso]><style>v\:* {behavior:url(#default#VML);}o\:* {behavior:url(#default#VML);}w\:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}</style><![endif]><p class="MsoNormal"><span style="font-size:14.0pt">Thanks for the question about fixed gear. Here in Florida I fly off of grass strips and most flyers fly 1/4 scale or larger. Fixed gear works the best.</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">[img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image001.jpg[/img][img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image002.jpg[/img][img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image003.jpg[/img]</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">[img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image004.jpg[/img] [img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image005.jpg[/img][img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image006.jpg[/img]</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">[img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image007.jpg[/img] [img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image008.jpg[/img][img]file:///C:\Users\Jim\AppData\Local\Temp\msohtmlclip1\01\cl ip_image009.jpg[/img]</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">The pictures above will give you an idea of what I do. I am sure this is not the only way, but is one way.</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">1. I cut the bottom of the fuse with a dremel cutoff disk to give the opening for the gear. Save that piece as you will use it to close up the space as the last step. </span></p><p class="MsoNormal"><span style="font-size:14.0pt">2. Set the gear on the fuse and see that the vertical fin is 90 deg to the table</span></p><p class="MsoNormal"><span style="font-size:14.0pt">3. Wrap the gear in waxed paper and glue the wood brace inside the fuse with slow cure expoxy. I use West Systems epoxy. There may be better b but you can get pumps that will give a proper mix every time. Thicken with milled glass (Great Planes) and apply.</span></p><p class="MsoNormal"><span style="font-size:14.0pt">4. After all is dry set the gear on the fuse. Install a T pin at the bottom of the vertical fin use a length of thread that does not stretch use a slip not at the end and attach to the T pin. Put a short piece of masking tape on the thread where the edge of the gear is and drill <u>one</u> hole through the gear and wood plate install a blind nut and (suggest 6-32) tighten to hold in place. Remeasure tighten and remeasure then drill second hole opposite side of fuse. Install 5 bolts, 2 on each side and 1 in the center.</span></p><p class="MsoNormal"><span style="font-size:14.0pt">5. Now work on the piece of fuse you cut out. Most likely the sides will be to long adjust to fit. Use 1/8 ply to attach to fuse with 4 -40 bolts</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">The last picture is what happened when I used retracts on a test bird (LA-2 with one piece wing). It was pilot error, I was too fast at touchdown and caught a small rut.</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">Any questions please call any time. If I am not in the shop call my cell. 239.821.4195</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt">Jim Graham
www.rccityfl.com
</span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><p class="MsoNormal"><span style="font-size:14.0pt"></span></p><![if gte mso 9]><xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:TrackMoves /><w:TrackFormatting /><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText> false</w:AlwaysShowPlaceholderText><w:DoNotPromoteQF /><w:LidThemeOther>EN-US</w:LidThemeOther><w:LidThemeAsian>X-NONE</w:LidThemeAsian><w:LidThemeComplexscript&gt;X-NONE</w:LidThemeComplexscript&gt;<w:Compatibility><w:Bre akWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><w:DontGrowAutofit /><w:SplitPgBreakAndParaMark /><w:DontVertAlignCellWithSp /><w:DontBreakConstrainedForcedTables /><w:DontVertAlignInTxbx /><w:Word11KerningPairs /><w:CachedColBalance /></w:Compatibility><w:BrowserLevel>MicrosoftInternetE xplorer4</w:BrowserLevel><m:mathPr><m:mathFont m:val="Cambria Math" /><m:brkBin m:val="before" /><m:brkBinSub m:val="--" /><m:smallFrac m:val="off" /><m:dispDef /><m:lMargin m:val="0" /><m:rMargin m:val="0" /><m:defJc m:val="centerGroup" /><m:wrapIndent m:val="1440" /><m:intLim m:val="subSup" /><m:naryLim m:val="undOvr" /></m:mathPr></w:WordDocument></xml><![endif]><![if gte mso 9]><xml><w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"DefSemiHidden="true" DefQFormat="false" DefPriority="99"LatentStyleCount="267"><w:LsdExcep tion Locked="false" Priority="0" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Normal" /><w:LsdException Locked="false" Priority="9" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="heading 1" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8" /><w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9" /><w:LsdException Locked="false" Priority="39" Name="toc 1" /><w:LsdException Locked="false" Priority="39" Name="toc 2" /><w:LsdException Locked="false" Priority="39" Name="toc 3" /><w:LsdException Locked="false" Priority="39" Name="toc 4" /><w:LsdException Locked="false" Priority="39" Name="toc 5" /><w:LsdException Locked="false" Priority="39" Name="toc 6" /><w:LsdException Locked="false" Priority="39" Name="toc 7" /><w:LsdException Locked="false" Priority="39" Name="toc 8" /><w:LsdException Locked="false" Priority="39" Name="toc 9" /><w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption" /><w:LsdException Locked="false" Priority="10" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Title" /><w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font" /><w:LsdException Locked="false" Priority="11" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Subtitle" /><w:LsdException Locked="false" Priority="22" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Strong" /><w:LsdException Locked="false" Priority="20" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Emphasis" /><w:LsdException Locked="false" Priority="59" SemiHidden="false"UnhideWhenUsed="false" Name="Table Grid" /><w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text" /><w:LsdException Locked="false" Priority="1" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="No Spacing" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 1" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 1" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 1" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 1" /><w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision" /><w:LsdException Locked="false" Priority="34" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="List Paragraph" /><w:LsdException Locked="false" Priority="29" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Quote" /><w:LsdException Locked="false" Priority="30" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Intense Quote" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 1" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 1" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 1" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 1" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 1" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 2" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 2" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 2" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 2" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 2" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 2" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 2" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 2" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 2" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 3" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 3" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 3" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 3" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 3" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 3" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 3" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 3" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 3" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 4" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 4" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 4" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 4" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 4" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 4" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 4" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 4" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 4" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 5" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 5" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 5" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 5" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 5" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 5" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 5" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 5" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 5" /><w:LsdException Locked="false" Priority="60" SemiHidden="false"UnhideWhenUsed="false" Name="Light Shading Accent 6" /><w:LsdException Locked="false" Priority="61" SemiHidden="false"UnhideWhenUsed="false" Name="Light List Accent 6" /><w:LsdException Locked="false" Priority="62" SemiHidden="false"UnhideWhenUsed="false" Name="Light Grid Accent 6" /><w:LsdException Locked="false" Priority="63" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6" /><w:LsdException Locked="false" Priority="64" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6" /><w:LsdException Locked="false" Priority="65" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 1 Accent 6" /><w:LsdException Locked="false" Priority="66" SemiHidden="false"UnhideWhenUsed="false" Name="Medium List 2 Accent 6" /><w:LsdException Locked="false" Priority="67" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6" /><w:LsdException Locked="false" Priority="68" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6" /><w:LsdException Locked="false" Priority="69" SemiHidden="false"UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6" /><w:LsdException Locked="false" Priority="70" SemiHidden="false"UnhideWhenUsed="false" Name="Dark List Accent 6" /><w:LsdException Locked="false" Priority="71" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Shading Accent 6" /><w:LsdException Locked="false" Priority="72" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful List Accent 6" /><w:LsdException Locked="false" Priority="73" SemiHidden="false"UnhideWhenUsed="false" Name="Colorful Grid Accent 6" /><w:LsdException Locked="false" Priority="19" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis" /><w:LsdException Locked="false" Priority="21" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis" /><w:LsdException Locked="false" Priority="31" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference" /><w:LsdException Locked="false" Priority="32" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Intense Reference" /><w:LsdException Locked="false" Priority="33" SemiHidden="false"UnhideWhenUsed="false" QFormat="true" Name="Book Title" /><w:LsdException Locked="false" Priority="37" Name="Bibliography" /><w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading" /></w:LatentStyles></xml><![endif]><![if gte mso 10]><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-priority:99;mso-style-qformat:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:11.0pt;font-family:"Calibri","sans-serif";mso-ascii-font-family:Calibri;mso-ascii-theme-font:minor-latin;mso-fareast-font-family:"Times New Roman";mso-fareast-theme-font:minor-fareast;mso-hansi-font-family:Calibri;mso-hansi-theme-font:minor-latin;mso-bidi-font-family:"Times New Roman";mso-bidi-theme-font:minor-bidi;}</style><![endif]>
jog0723 12-13-2012 10:46 AM
RE: Fixed gear Pattern Planes
1 Attachment(s)
crankpin 12-13-2012 12:02 PM
Jog - Good idea.
Crank
