Futaba programming
I need some of you "older" guys to help me. I have a futaba 8UAPS that I still fly with. I want to create a mix that ties all the dual rates to one switch. I cant remember how. If I mix Rudder, elevator, to the aileron with the dual rate switch as the control, will that do it? Thanks in advance for your help!
It's been a while since I've used one of these, but if I remember correctly, in the DR screen you can pick the switch you want to activate the DR on. If my dad's was here I could be more specific, but I'll try and have him bring it it tomorrow.
Bingo! You are correct. I just checked it, sure enough I set all the DR to the same switch. I should have rememberd, to much gray hair I guess! Thanks JAS!!!!
| All times are GMT -8. The time now is 08:59 PM. |
