RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Tower Kaos 40 Build Instructions (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/11655773-tower-kaos-40-build-instructions.html)
ma_mulcahy 10-24-2018 10:22 AM
Hello,
I bought one of these kits second hand and it came without the build instructions. As I recall from my prior build of the kit, it was only a double side sheet of paper folded in thirds. Does anyone on this forum have a copy I could purchase? I will pay any copying and postage costs.
Thank You!
RC_Fanatic 11-04-2018 01:12 PM
The instructions that came with my kit is a booklet with 64 pages, 8&1/2 x 5&1/2! :eek: Local copy shops will not copy it because of the copyright. Just started the kit and I'm a slow builder. If you can't get the one you recall in a few weeks, PM me and I'll see if I can find a way to scan it in.
ma_mulcahy 11-05-2018 12:16 PM
RC_Fanatic - Thanks for responding, but I think I mis-communicated. I am building the full kit and it sounds like you may be assembling the ARF from your description. If you're building the full kit, they sure did a good job rewriting the instructions!
RC_Fanatic 11-06-2018 04:13 PM
No, it is actually for the full kit. Tremendous amount of detail for the actual construction including cross-grain balsa on lower rear fuselage. That really should come after routing the controls but, to each his own. One for the ARF would only be 1/3 or less. They must have had some complaints early on.
Skyhawk940 11-07-2018 07:17 AM
I built a Kaos 90 from plans and I love the way it flys. Satio 120 will pull it straight up forever. Just starting to build a Mini Kaos. Very easy to build with a foam wing. I think you'll like it.
Skyhawk
Sandusky, OH
