Pattern Plane for Webra 120
Looking for some recommendations for a pattern plane for a Webra 120.
RE: Pattern Plane for Webra 120
Epsilon 1.20, check with Aeroworks as they are the sole US importer for CA Models.
ARF or KIT?
Most of the '90' size ARF pattern ships were designed around .90 4-strokes so the weight of the Webra 1.20 is comparable. You can also get wrap-around headers made by Karl Mueller for about $50 (custom made to your specs - first class quality). The MK Topstar 110 would be an excellent kit choice (available from Singapore hobbies - 2 versions: all wood kit or pre-sheeted foam wings, and stab). The wood kit costs about $310 shipped. The wood/foam version is about $460. You can also check PAC's website for some of the older designs designed for 4-stroke 1.20s such as the Desire and others. Good Luck, Will B. |
| All times are GMT -8. The time now is 05:38 AM. |
