RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Crusader (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/3963705-crusader.html)
8178 02-26-2006 05:29 PM
Crusader
Has anyone on the forum built a Crusader designed and flown by the world champ,Ralph Brooke? I have a set of MAN plans from 65 and it looks like a tough build with a carved out fuselage top and an egg crate wing. I guess you would need an open exhaust Fox 59 for the full impact!
rainedave 02-26-2006 08:53 PM
RE: Crusader
Way too young here, but I have an 8 1/2 x 11 copy of the plans in front of me. The drawings I have show optional conventional ribs and includes foam templates.
I have built a few geodetic (egg-crate) FF wings and it's a lot easier than it looks. I assembled rectangular rib blanks with plywood root and tip ribs. Then using a lond sanding bar, shaped the ribs to the airfoil contour. The ply ribs act as a guide for sanding. Sort of like sanding a foam core down to the templates instead of cutting with hot wire. It can actually be easier than cutting out individual ribs for a tapered wing. Lots of old FF stabs were done this way, too.
I agree that the fuse top would be a lot of work.
rainedave 02-26-2006 09:02 PM
RE: Crusader
1 Attachment(s)
I'm still working away on the Perigee plans but it would be cool to maybe consider:
8178 02-26-2006 09:48 PM
RE: Crusader
Thanks for the ideas! I’m just investigating ideas for my next build.
Your CAD work looks very good.
