help with engine chose
i am thinking about getting a tojeiro 50 pattern plane .
. Technical specifications: Wingspan: 52.17" (1325mm) Length: 55.12" (1400mm) Wing area: 596.75 sq in (38.5dm²) Weight: 4.85 lbs (2.2kg) Engine: 2C .40-.46 size 4C .52 size Glow engine do you think an o.s fx 46 has the thrust needed for this model? do you think its a good idea to fit an fx 61 up front? is the fx 50 that much stronger that it wiil make a difference over the fx 46 ? |
RE: help with engine chose
amstaff, looking at the specs, my opinion is that a .61 is too much engine. You may want to search RCUniverse for "tojeiro" and see what others are using.
| All times are GMT -8. The time now is 01:35 PM. |
