RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   COSMOS 60 (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/4425433-cosmos-60-a.html)
vinnyjet 06-24-2006 10:37 AM
COSMOS 60
looking for CG
and throws
thanks
vinny
Deadstik 06-26-2006 03:14 PM
RE: COSMOS 60
Vinny,
I don't have the Cosmos plans anymore, but I do have the Aurora plans which was maybe 25 cents different than a Cosmos. I'd be happy to look up the C/G/throws if you'd like them. I flew both and the Aurora was a bit smoother due to the lengthened fuselage.. but I'd bet the C/Gs are almost the same. Let me know.
Dan
Carolina Custom Aircraft
dlb 06-27-2006 10:49 AM
RE: COSMOS 60
I looked up the plans to my Cosmos 60 and the CG location is around 1/4 inch forward of the main gear position which seems too me to be a bit too far back. As I recall I flew my Cosmos 60 with the CG about 1/3 back for the leading edge of the wing. Throws are not mentioned on the plans for the Cosmos 60 nor on the Aurora plans either. So I would suggest 1/4" up and down on the Ailerons, 3/8" inch up and down on the elevator the Rudder I used 1 inch both directions to start. If you had installed the flaps try 45 Deg down initially and be prepared to feed something like 1/8 down elevator when the flaps go down since the nose of the Cosmos will pitch up and will try to go into a loop. I still have my Cosmos 60 after all these years built it 15 years ago and I have a 2nd Cosmos that has been ruffed in but never finished. I never set my plane up for the spoilers but the flaps all the way down really helped the airplane in the landings.
Dwight L Bogan
vinnyjet 06-27-2006 04:22 PM
RE: COSMOS 60
dlb and deadstik
thanks alot
it looks alot like an Aurora
vinny
dlb 06-27-2006 05:31 PM
RE: COSMOS 60
Well the Cosmos 60 is the predecessor to the Aurora by the same designer. The the Cosmos was a mid 80's design and was kitted by MK I assume you have an MK kit. I don't really know if anyone else produced a fibreglas version like was done with the Aurora that was known as the PA-2
DLB
Deadstik 06-27-2006 09:12 PM
RE: COSMOS 60
DLB,
Yes, Phillips Aircraft did the Fibeglass Aurora.. or PA-2..... you wouldn't know where one is hiding would you???..... I just recently obtained a Mistress.....anyway.. always looking for another classic.
Dan
dlb 06-28-2006 11:00 PM
RE: COSMOS 60
Yes I just happen to know right where a PA2 is hiding right now. Its in the 2nd bedroom in my house. Its about 75% done too. all that needs be done to it is the assembly of the tail section the wings and engine mount are already installerd. If your interested leave me a message. I've got so many projects I'm working on its still going to be a long time before I get to it.
Dwight L Bogan
