RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   What is this plane? (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/5154699-what-plane.html)
kaosfan 12-24-2006 12:34 AM
What is this plane?
1 Attachment(s)
I bought this plane at a swap meet. I don't know what it is except it looks familiar. For sure, it's not a Dirty Birdy.
It has a side mounted engine, .60 size, came with fixed tricycle gear, fiberglass fuse with fiberglass fin and appears to have a balsa over foam horizontal stab and double tapered foam/balsa single piece wing.
Thanks folks.
rainedave 12-24-2006 08:13 AM
RE: What is this plane?
1 Attachment(s)
I'm going to say it's a Deception, but I am very far from being an expert on these planes.
Allie33 12-24-2006 09:15 AM
It sure looks like a Deception, I just went to the hangar and looked at my one remaining.
I never saw a glass fuselage version though. Mine took a whole lot of carving as I remember.
AW
Paternguy 12-24-2006 10:39 AM
The tail looks wrong for a Deception. It looks like one of the birds from Southern R/C.
Skylane 12-24-2006 10:44 AM
Hi Al,
The wing is not that of a Deception. The Deception wing has a greater sweep on the leading edge than on the trailing edge whereas this one looks to have equal taper fore and aft. I don't recognize this one.
Jeff
CoosBayLumber 12-24-2006 10:47 AM
Wasn't some firm on East Coast , like in New Jersey selling something like their interpretation of an Atlas? Was advertised with F.B. fuselage and foam wing in early 1980's. They had a model of 40 size, which apparently sold better for it was bleeped from advertisements. Only the 60 size went for a few years.
The rudder and the engine are about only thing familair to me, other than at their clearance time a few years later those same models went rather cheap. I think it was just less than $50, and free shipping.
Wm.
Allie33 12-24-2006 11:25 AM
Still looks like a Deception, but maybe a knock off, glass fuselage. Couldn't comment on the wings though because mine are still stored in ,as you might remember, that Budwiser bag that the wife was nice enough to make for me 25 years ago.
BTW, I was looking over the UFO. It seems that the "sorgum" that I used has allowed the sheeting to separate from the foam at the root of 1 wing. Ron thinks Gorilla glue would be the best product to stick it down. I think it may be too viscus to reach the inner portion, maybe 3 inches in a V shape.I wonder about foam safe CA.
If anyone out there has an idea please chime in.
AW
Paternguy 12-24-2006 11:40 AM
Gorila glue is a bad idea, it expands as it dries, it will buldge the skins. I would go with the foam CA.
Deadstik 12-24-2006 12:16 PM
Kaosfan,
It looks to be a Bootlegger knock off... and that the Bootlegger didn't have a double tapered wing.... I'd check with somebody who does have a Southern R/C ad.... they could tell you whether this was a kitted plane or not.... and... I've never seen a fiberglass Deception either... Merry Christmas !!!
Dan
Carolina Custom Aircraft
kaosfan 12-24-2006 01:32 PM
I am still researching this one. At first glance I thought maybe the builder had modified a Dirty Birdy kit. Upon closer look I don't think so. This one has a lot of work to be done on it but it seems to have come out at an acceptable weight.
The Bootlegger fuse I have seen in previous forum posts doesn't have the fiberglass fin on it.
By the way, does anybody have a picture of a Compensator? I can't seem to find one.
Funny thing about your UFO project AW. I have the same exact problem with mine.
Thanks folks and Merry Christmas.
rainedave 12-24-2006 02:37 PM
1 Attachment(s)
Here are the plans for the Compensator.
Allie33 12-24-2006 05:09 PM
Right on
I just went through some old photos. That is definately a Bootlegger tail section, and it was a resin/glass fuselage as I remember. Can't get to the attic to check the wing, too old and too much egg nog.
impactiq 12-25-2006 01:33 AM
I would half to go with the Allie and Deadstik on this. The plane does have the lines of the bootlegger. One sure way to tell if it is a Southern R/C kit is if the inside of the fuse (wing saddle are) is of a blue-ish color resin.
roncoleman 12-25-2006 03:25 AM
1 Attachment(s)
Looks like it may be a modified copy of the bootlegger design. The fuse wing
saddle isn’t deep enough at the trailing edge to be a Southern Bootlegger.
See photos
Bootalini 12-25-2006 08:41 AM
Ron, nice looking Bootlegger! Obviously an old TOC edition.
roseberry 12-25-2006 09:45 AM
Merry Christmas boyz,
Well I believe what we have here is a design produced and used on the west coast called a Camino. I think it was produced about the same time frame as the Baranoski sp? Darrainger that would be early 80's.
On the topic of the the glass Deception yes there was a all glass Deception. It was produced by I think Troy or Todd Allen (memory fade) it was all glass with "glasskin wings" ala Bob Smiths T2A. I would love to get my hand on one again.
Mike
woodie 12-25-2006 09:59 AM
ORIGINAL: roseberry
Mike
The El Camino was a knock off of the Super Kaos with more rounded fuselage in the upper corners. It was all balsa like the Kaos. This wing plan/airfoil and the way the wing fits in the fuselage is very Kaos like tho the fin is larger......
I dunno, would have guessed modified Kaos or El Camino but they were all wood. I am not aware of a Kaos fiberglass version.
Woodie
kaosfan 12-31-2006 06:31 PM
Rainedave, thanks for the Compensator pic. That was quick too.
Happy New Year all!
WEAVE 01-06-2007 01:04 AM
This is a Rhett Miller design called the Compensator I flew this plane for a couple of years. This is a great flying bird. Good luck with your plane and happy flying. Ronnie Weaver, Garner, NC.
mjfrederick 01-06-2007 02:58 PM
So has there been a consensus on what the original plane at the top of this post is? I've been racking my brain to try and figure it out. At first glance I thought Bootlegger, but I went in the attic and checked the Bootlegger fuse I have, and the previous comment was correct in that the rear of the wing saddle is not deep enough. It's not a Compensator as the Compensator was not sold with a fiberglass fuse (not by Southern R/C anyway), that was why the Bootlegger was developed, it was a glass-fuse version of the Compensator, Another reason I say it's not a Compensator is that the canopy is way too long (I'm looking at a picture of my dad's old Compensator as I type this, and I'm also building a Gator Flea, the 40-sized Compensator). It definitely looks something from Southern R/C though. I seem to remember the Tiger Tail having very similar lines to the Bootlegger, perhaps that's what this is? I don't even remember if the Tiger Tail was produced by Southern R/C, but from what my dad has told me over the years, Ron Chidgey, Rhett Miller, and Steve Helms all used very similar lines in their designs and it was sometimes hard to tell one model apart from another.
Roguedog 04-06-2008 12:17 AM
1 Attachment(s)
Hey Kaosfan.
This looks like a later Model El Camino by Ed baranowski. There were several guys flying them were I used to fly in Ontario California. He was pumping these planes out during the early to mid eighties. They were priced at $300.00 according to the gents that purchased them. There were 3 different paint schemes and believe it or not they were ARF's cough! cough!
If I remember correctly he was also making Curares as well.
I sure wanted one bad. I think the guys that had them got tired of me coming over to admire them. Fiberglass fuse with foam wings, already painted. They had Screaming Sixties with tuned pipes, i believe mostly Webras.
I liked one so much I copied the paint scheme onto my Sig Kobra (see pic). On one occasion, I remember one of the planes got hit with interference, it did five or six beautiful loops in a row and then plowed into the field next to the street we landed on. Ouch! I remember everbody got quiet and waited to see his reaction. I would've had a aligator tear or two, as well, if it was mine.
And Yes Ed Baranowski made an early version with the same name. But I believe that this plane is a early to mid eighties version of his earlier plane. I've never seen the earlier version and haven't seen the later model one since then, but sure would like to have the one in the picture above. I've included a pic of the earlier version as well, its the only pic I could find of either until the pics above.
locolobot 04-06-2008 07:34 AM
1 Attachment(s)
O.K. My turn to have a question.I rebuilt a plane for a friend and for this favor he gave me this plane. We are not sure what it is nor where the kit was manfactured. It is a built up balsa and ply aircraft. It came to me completely covered in red monocote without a vertical stab. I built the vertical stab that is now in place on it. I also ordered and cut a canopany from a extra 300. So the canopany is something other than original. I have ordered a cowl to fit it since I am not sure wheather it is supposed to have a home built cowl or a glass one. I sure would appreciate it if someone can tell me what it is and provide me with some information on it or where I can obtain prints for it.. Thanks a bunch for your input.
Thanks again
Jack
Allie33 09-21-2008 08:39 PM
Just ran across your post and wondered:
Did you do anything about the lifting balsa on the wing? I think I used epoxy on the stab, but it was a long time ago. Twenty six or so years ago. I'll have to go to the attic and look at it, when time permits.
AW
