RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Curare dehidral (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/5405618-curare-dehidral.html)
susquach 02-11-2007 10:35 PM
Curare dehidral
I'm going to start a Precision Models Curare that had been started by that original owner. Here's the problem: The wings were assembled with (what the original owner feels is) too much dihedral. I don't have the original plan set to refer to so I don't know what the correct dihedral should be. Anybody got a clue?????
rainedave 02-11-2007 10:52 PM
RE: Curare dehidral
1 Attachment(s)
This is the dihedral detail from the Model Airplane News plans. I have no idea whether or not other kit releases were different.
ppljr 02-11-2007 11:17 PM
RE: Curare dehidral
1 Attachment(s)
Here's the MK version:
pimmnz 02-12-2007 12:07 AM
RE: Curare dehidral
And 75mm = 3".
Evan.
rainedave 02-12-2007 10:07 AM
RE: Curare dehidral
On another discussion list there was a case where someone had built a highly modified DB with no dihedral (it did have section thickness taper dihedral) and no wing tips. The pilot was having all sorts of trim issues. In other words, the dihedral that the designer settled on is probably the best choice. Especially, if we're talking about people like the Prettners. If I were building one I'd go with the 3"/75mm called for.
Steve25 02-12-2007 10:39 AM
RE: Curare dehidral
Mk Curare/Minare 40 :
Wing : 55mm
Stab : 95mm
Mine is build with less, ie, if you would measure the wing on the upper side, it's straight, and the only dihedral that it has, is due to the profile getting thinner on the tips.
Still, it was flying like on rails
Stripes 02-12-2007 04:33 PM
RE: Curare dehidral
:eek:
3 inches = 76.2 MM [8D]
susquach 02-12-2007 08:20 PM
RE: Curare dehidral
Two, four, six, eight....I ain't gonna metricate.
Thanks for the help guys....three inches it is.
rainedave 02-12-2007 09:06 PM
RE: Curare dehidral
If I were you I'd split the difference and go with 2 63/64" just to be safe.:D
Stripes 02-13-2007 08:28 AM
RE: Curare dehidral
ORIGINAL: susquach
Well you are going to be OK here in the USA but don't take it outside because it won't fly worth a hoot in a metric country if it is in inches. ;)
CoosBayLumber 02-13-2007 09:45 AM
RE: Curare dehidral
According to the plan I have, it cites 2 degrees to each side of fuselage, as measured along centerline of wing. This is not the upper or lower surface. The tailplanes are 9 degrees downward to each side of the fuselage also.
Since the ribs, shown, die cut and drawn, do not fit the lines of the intended wing very well, I went and redrew the whole plan in CAD and used the above noted angles for determining the offset near tip.
Wm.
susquach 02-16-2007 12:16 PM
RE: Curare dehidral
Thanks for the info on the horizontal...I forgot to ask about it when posting.
