gyro on planes
when is a gyro used on a plane?
RE: gyro on planes
When they turn it into a helicopter...[sm=tongue_smile.gif]
When you need extra weight for balancing.....[sm=spinnyeyes.gif] No, really I have no idea...I've never heard of that.. I could use it as a good RC trivia question if its true. You learn something new everyday... Does anyone know? |
RE: gyro on planes
ORIGINAL: cessnat210 When they turn it into a helicopter...[sm=tongue_smile.gif] Have Fun... Chuck |
RE: gyro on planes
ORIGINAL: stargate when is a gyro used on a plane? Mark |
RE: gyro on planes
I recall years back they did some experimenting with unstable cg positions and gyro pitch control. Can't remember which mag, however.
RE: gyro on planes
I've seen them used in some of those exact-scale, $30,000 turbine jets. Like Mark said, sometimes a scale tail outline isn't adequate for a model, although it may be more than enough area on the full size plane. The Hawker Hurricane is an example of a scale plane where model designers will often increase the tail area (or use a gyro).
RE: gyro on planes
I think they are illegal for both pattern and IMAC events. So no reason to use them in practice. The only time I know of is for distance record planes, which may also include GPS control.
RE: gyro on planes
ORIGINAL: Sport_Pilot I think they are illegal for both pattern and IMAC events. So no reason to use them in practice. The only time I know of is for distance record planes, which may also include GPS control. |
RE: gyro on planes
Thanks for all the input fellow flyers! [sm=thumbs_up.gif]
| All times are GMT -8. The time now is 03:40 AM. |
