RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Which Y.S.? (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/6320199-y-s.html)
Dicky168 09-02-2007 10:15 PM
Which Y.S.?
I'm planning to build a Venus II and I'm wondering what Y.S. model is preferable for good perfomance?
jetmech43 09-02-2007 11:27 PM
RE: Which Y.S.?
the 110
Dicky168 09-03-2007 08:56 PM
RE: Which Y.S.?
Can the 110 be invertly mounted? Also, did you use with or without pump? What muffler did you use? Thanks for your reply.
jetmech43 09-03-2007 10:12 PM
RE: Which Y.S.?
I do believe the YS 110 has abuilt in pump as do all YS engines, shoudnt be a problem mounting it inverted
Nathan King 09-04-2007 07:20 AM
RE: Which Y.S.?
Yes, the engine has a built in pump and comes with a frond mounted regulator. With the YS you can place the fuel tank almost anywhere and the engine will run beautifully. The 110 will give the Venus 2 great power.
Enjoy
Dicky168 09-04-2007 08:14 PM
RE: Which Y.S.?
Thanks for you reply, Jet, Nath. Btw, what kind of muffler did you use? I'm refering to the muffler that canbe positioned under the cowl.
