RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   B&D Retracts (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/6720902-b-d-retracts.html)
JeffH 12-06-2007 09:22 AM
B&D Retracts
Does anyone know if B&D is still in business?
edp 12-06-2007 08:39 PM
RE: B&D Retracts
Jeff
YES, I see them at the Toledo show every year. Talked to them and said there was a misunderstanding w/ Tower. Try your LHS. If no luck I have a NIP tri-gear air set if you need them.
Atlanta 60 12-06-2007 11:03 PM
RE: B&D Retracts
I did a little google searching...I came across these links:
http://www.advantagehobby.com/produc...cat=691&page=1
(Discontinued??)
B&D
Phone: (304) 753-4636
They look pretty nice from what you can tell in the pictures...Are these pretty good retracts??
Thanks...
Chuck
edp 12-06-2007 11:35 PM
RE: B&D Retracts
Chuck,
Yes, These are what I put in all my pattern ships. They seem to bullet proof. I do add air line restrictors to that slap up/down look.
JeffH 12-07-2007 08:58 AM
RE: B&D Retracts
They are great retracts for pattern type planes. Well built, smooth, and they used to have lifetime warranty. Their valves were far better than the Rhom type valve.
bob27s 12-07-2007 10:43 AM
RE: B&D Retracts
I have used B&Ds a few times...... good gear. Pretty good value on the compelte system.
Only issue that may come up - the mounting flanges on these gear are about 3/32 - 1/8" thick. As opposed to the 1/16" thick flanges on most air and mechanical gear with metal frames. This just means your gear mount plates have to be a bit deeper below the wing skin for proper installation. Not really a problem, just something to keep in mind when building.
Note the nose gear dimensions as well. They fit in 90% of normal installations without issue - but the nose unit is a bit larger than the typical light-weight mechanical nose gear.
Bob
Dean Pappas 12-07-2007 04:40 PM
RE: B&D Retracts
Hello Chuck,
I used B&D mechanicals exclusively on my Pattern ships ever since I first tried them. The long locked-range at both ends makes them ideal for plug-in wings, too.
Typically I would use the Bob Violett 5/32" struts in them Those are among the best around.
Dean Pappas
Atlanta 60 12-08-2007 02:28 AM
RE: B&D Retracts
Thank You All...I had never heard of the B&D Retracts before...
I'll be flying off a grass runway...I have a few sets of el-cheepo retracts but kinda figured they wouldn't last too long...I need more sets anyhow so I was thinking of trying Supra Retracts but I don't see a nose gear available...And they are expensive!!
Only other "Higher Quality" mechanical retracts I know of are Dave Brown's which I would not mind...They were my option if I couldn't do Supra...
But these B&D's sound pretty dang nice...
Thanks Allot!!
Chuck
