The Fugitive
1 Attachment(s)
Going back to the early 70"s or so for this Pattern Ship designed by Jim Brittain. The construction includes a jig with a wrapped plywood fuselage. I don't see this type of construction too often. Anyone remember this design?
RE: The Fugitive
Yes, I remember it. Back then, there were several examples of "out of the box" engineering like wrapped ply bodies, cardboard wings, etc. It was a marvelous time of invention.
RE: The Fugitive
I remember that article. It says 7 1/4 - 7 3/4 lbs. Not too shabby. Any opportunity to get away from the trouble of selecting balsa is a good thing.
Tom |
RE: The Fugitive
it is, but you might be VERY suprised at the difference in cost of trying to get a sheet of 1/32 ply in the right size you need.
Having said that, I've always looked at the plans for the "fuge" with interest, I'd love to see a build log for one if you decide to take the plunge! |
RE: The Fugitive
ORIGINAL: Rendegade it is, but you might be VERY suprised at the difference in cost of trying to get a sheet of 1/32 ply in the right size you need. Hope this helps. Andy |
RE: The Fugitive
I've read that some are using 1/64" ply as a substitute for 1/16" balsa.
Tom |
RE: The Fugitive
I've used 1/64" ply as wing sheeting, it works well and doesn't need much fairing before it's ready for paint.
Having said that, these days I'm experimenting with carbon/glass skins. |
RE: The Fugitive
That's probably the most accurate way to make wings. Skin it and vacuum bag it like the sailplane guys.
Tom |
| All times are GMT -8. The time now is 10:46 PM. |
