RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Pull-Pull with Mylar - Need Advice (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/8687411-pull-pull-mylar-need-advice.html)
crankpin 04-16-2009 02:43 PM
1 Attachment(s)
First time with Mylar, I have used braided cable in the past. Hooked up with one loop thru the threaded link, front and back. Is this going to hold up ? Anyone have any problem's with this method ? I am concerned about the thread wearing. Bought from one of the biggie's, Central, TBM, forget which. It is in the Focus Sport. If it could be an issue, I will take it out, pronto.
Crank
8178 04-16-2009 03:10 PM
RE: Pull-Pull with Mylar - Need Advice
I used a threaded eye hooks and clevis on the servo end and connected directly to the adjustable Dubro nylon horn at the rudder. I think the eye hooks came with the pull-pull kit and they have a smooth surface for the cord as well as the DuBro horns.
lfinney 04-16-2009 07:05 PM
add a drop or two of thin CA to the knot and you should be fine
crankpin 04-23-2009 06:02 PM
Thanks to you all for the good advice.
Crank
