Wheel well material ?
Gentlemen,
Besides using light ply or yogurt cups, what material would be good to line the wheel wells of a foam core wing ? I was thinking about just giving the foam a couple of coats of finishing resin but like a more finished look. I know Hangar 9 and some others sell vacuum form wheel wells but getting the right size might be tough. Thanks in advance for any suggestions, paul |
RE: Wheel well material ?
I seem to remember using the tops off aerosol cellulose paint cans?
For foam wings 1/64 plywood works best for me. Take a look at the Blue Angel or Speeda build to see how it looks.
I have a tipoare that someone used coke cans it looks very good
I used 1/32" balsa. Worked great.
Paul,
Mike's and Frank's suggestions are pretty much the standard. Some prefer 1/16" balsa depending on the size of the model. However, I think that if you are planning to just paint the wells, 1/64" ply might be preferable (doesn't absorb as much and is strong). On the other hand, if you plan to glass and paint, then balsa might be the way to go. If you plan to cover, then use balsa but covering wells is pretty tedious. David. |
ORIGINAL: pacoflyer Gentlemen, Besides using light ply or yogurt cups, what material would be good to line the wheel wells of a foam core wing ? I was thinking about just giving the foam a couple of coats of finishing resin but like a more finished look. I know Hangar 9 and some others sell vacuum form wheel wells but getting the right size might be tough. Thanks in advance for any suggestions, paul -Robert |
I've used thin plastic sheet that is stocked in some hobby shops. It's lite in weight, works great and is gray in color so that it is not necessary to paint them.
John |
FOR WHAT IT'S WORTH
I wrap 3 or 4 layers of 1/16" balsa around a can or something round , glued together of course and held in place with rubber bands over night. when this is done it is perfectly round and the size I need. I then smear some epoxy on the inner surface just to seal the wood. When dry I sand smooth , wax with partall wax , spray with PVA , lay it on a piece of old glass, then I fiberglass the inside. When it dries I pop it out and I have a perfect , light weight wheel well that is the size I want. I know it soounds like a lot of work, but it really isn't.[8D] |
ORIGINAL: frequent flyer FOR WHAT IT'S WORTH I wrap 3 or 4 layers of 1/16'' balsa around a can or something round , glued together of course and held in place with rubber bands over night. when this is done it is perfectly round and the size I need. I then smear some epoxy on the inner surface just to seal the wood. When dry I sand smooth , wax with partall wax , spray with PVA , lay it on a piece of old glass, then I fiberglass the inside. When it dries I pop it out and I have a perfect , light weight wheel well that is the size I want. I know it soounds like a lot of work, but it really isn't.[8D] that's a great way to create wheel wells. |
Thanks to all who have responded
paul |
FF,
Could you not just glass over the end of a beer can / bottle? . . ORIGINAL: frequent flyer FOR WHAT IT'S WORTH I wrap 3 or 4 layers of 1/16" balsa around a can or something round , glued together of course and held in place with rubber bands over night. when this is done it is perfectly round and the size I need. I then smear some epoxy on the inner surface just to seal the wood. When dry I sand smooth , wax with partall wax , spray with PVA , lay it on a piece of old glass, then I fiberglass the inside. When it dries I pop it out and I have a perfect , light weight wheel well that is the size I want. I know it soounds like a lot of work, but it really isn't.[8D] |
[quote]ORIGINAL: klhoard FF, Could you not just glass over the end of a beer can / bottle? . . You sure could if it is the correct diameter that you need. |
| All times are GMT -8. The time now is 11:16 PM. |
